Petcock Sealing Washers
    • 4015
    The sealing washers that go under the head of the bolts that seal the petcock to the tank. I know the part numver, etc. Done the research on them. Need to be fuel resistant. Viton is recommended. Anybody use anything else that works? Copper crush washers?
  • MPittma100
    • Aug 2011
    • 2359
    Washers
    Just bought some of the OEM replacements. Have not tried anything else since these are still available. OEM screws are also available.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      Fiber washers are correct for this application, they need little torque to seal the fuel and are rigid. I would imagine copper crush washer would need a higher torque which may not be a good thing here. Rubber viton may be too soft and would deform when tightened I would think.
        • 4015
        U paid $4+/each for four washers?
          • 2104
          Fibre washers can be found at a good local hardware in the fastener section.
          • MPittma100
            • Aug 2011
            • 2359
            Washers
            I paid $1.78 each for the washers plus shipping from Partzilla. Bought the screws as well - same price each.
            Or I could have wasted time and money on gas running around hoping to find something that "might" work.
            On the other hand, if the correct part is no longer available, I will waste time and gas money to find something that may work.
            K&N Air Filter
            ACCT
            EBC Front Rotors
            Mike
              Time is money!
