The sealing washers that go under the head of the bolts that seal the petcock to the tank. I know the part numver, etc. Done the research on them. Need to be fuel resistant. Viton is recommended. Anybody use anything else that works? Copper crush washers?
Petcock Sealing Washers
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Tags: None -
Washers
Just bought some of the OEM replacements. Have not tried anything else since these are still available. OEM screws are also available.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
Mike -
Fiber washers are correct for this application, they need little torque to seal the fuel and are rigid. I would imagine copper crush washer would need a higher torque which may not be a good thing here. Rubber viton may be too soft and would deform when tightened I would think.2H7 (79) owned since '89
☮Comment
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Fibre washers can be found at a good local hardware in the fastener section.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Washers
I paid $1.78 each for the washers plus shipping from Partzilla. Bought the screws as well - same price each.
Or I could have wasted time and money on gas running around hoping to find something that "might" work.
On the other hand, if the correct part is no longer available, I will waste time and gas money to find something that may work.1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
MikeComment
