1.7 ohms is within the tolerance range. The caps are the boots the sparkplugs plug into. Should see upto 25k across them with the boots on (each coil). And, the plugs do not "un-plug", they screw off. Grab the plug wire firmly, and unscrew the plug cap.
I know u cleaned your carbs, but did you make sure your idle screw tips were not broke?
