Fired up for the first time, how to keep it running?
    • 3951
    1.7 ohms is within the tolerance range. The caps are the boots the sparkplugs plug into. Should see upto 25k across them with the boots on (each coil). And, the plugs do not "un-plug", they screw off. Grab the plug wire firmly, and unscrew the plug cap.
    I know u cleaned your carbs, but did you make sure your idle screw tips were not broke?
    • oakback
      • Jul 2014
      • 69
      • Tallahassee, FLA.
      #77
      I'm getting 14.3 across each pair with caps removed.
      I'm not sure what the idle screw tips are, I'll research and get back to you.
      80 G
      • oakback
        • Jul 2014
        • 69
        • Tallahassee, FLA.
        #78
        I don't remember what they looked like when I had it apart, I'll pull them out tonight or this weekend and see.
        80 G
        • ekim
          • Jun 2013
          • 106
          #79
          Remember to keep your battery topped up during all this testing and diagnostic work. the battery is under a drain whenever the key is on. The charging system doesn't kick in until the motor is running at 2500 rpm. Put it on a trickle charge (2 amp or less) between troubleshooting sessions.
          Keep at it. These guys are the masters and WILL get you going.
          1980 XS1100 Standard (G)
          Original Owner
          Stock plus:
          2011 FJR1300
          1978 SR500
          • oakback
            • Jul 2014
            • 69
            • Tallahassee, FLA.
            #80
            Battery is dead, I've been jumping it from my car. I didn't want to waste money on a new battery if the engine ended up been trash.
            80 G
              • 3951
              In the case of resistsnce measuring, voltage should not be supplied. Other than checking voltage to the coils, you should be good. Did you check voltage across the battety before, and during crank?
              • oakback
                • Jul 2014
                • 69
                • Tallahassee, FLA.
                #82
                I charge it for 10 hours, and it might crank the engine for 3 seconds. Pretty sure it's dead.
                80 G
                  • 3951
                  Lol, I hope you understsnd that with these bikes being TCI-based, and not points & condensors, the bike is dependent on a healthy battery. Bad batteries cause funny things.
                    • 7818
                    Even jumped, the XS1100 WILL NOT RUN WITH A DEAD BATTERY!! Been there, tried that with a couple of other members here for someone who has since passed. We were working on his bike, and had BIG cable between his battery and the car battery. engine would not start. Bought a new battery, charged it, and bike fired right up.
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Gremlins
                      Sometimes one or more of the spade terminals inside of a multi-connector plug get damaged beyond repair. Rather than replace both halves of the connector, you can go around the connector by butt connecting the affected wire(s).
                      The damage is not necessarily caused by dirty connectors, but rather by too much (electrical) resistance caused by poor or improper grounds. The fix for this problem is to ground everything to the battery rather than the chassis. This will cure/end a whole lot of gremlins in these bikes.
                      Look for battery grounding in the search heading.
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                      • oakback
                        • Jul 2014
                        • 69
                        • Tallahassee, FLA.
                        #86
                        Good to know! I'll see about getting a battery ASAP.
                        80 G
                        • oakback
                          • Jul 2014
                          • 69
                          • Tallahassee, FLA.
                          #87
                          Here they are:
                          80 G
                            • 3951
                            Hmm. The pic could be fuzzy, but the tips all look broken.
                            • oakback
                              • Jul 2014
                              • 69
                              • Tallahassee, FLA.
                              #89
                              I got it running.
                              I pulled the pilots again. I didn't realize there was a hole in the non-slotted end. Cleaned that and reassembled. Cranked right up, even idles on its own. Got a lot of fuel/rich smoke, but at this point I don't care, I'm just really excites it runs.
                              80 G
                                • 8893
                                The idle mixture screws for years 80 and up look like the ones in the above picture, they are not the pointed type of the earlier carbs.
