Street fighter/ Bobber build 2.0
  • Fearthepack
    • May 2012
    • 255
    • Orlando, Fla.
    #286
    Thanks...and I did the ACT upgrade a while ago so a little more worried now and when I removed it its was engaged.
    Although i understand how things work I have no life experiences to go with it...So should I automatically assume bent valves and will it be just one on both intake and exhaust or more. What procedure 1st to last do I follow? reset timing and pray or just remove the head and dissemble all valves and fix as needed. I just don't know what to expect at this point. I think i'm moving backwards!
    1979 F worst one i could find
    to convert into a bobber/ streetfighter!
    _________________________________
    We can't all get along!
      • 5062
      #287
      OK, I’ll bite. Adjust your cam chain for correct timing. Then do a compression check. At least you will get an idea which cylinder’s valves are affected. You will not know however if it is the intake valve, exhaust valve, or both for the low compression cylinder. Price-out a head gasket, a valve cover gasket, valve seals (these things can come in a top-end gasket kit), and possible valves affected. You will not know which valves until you pull the head and check for solvent leakage with the valves all closed. OK, now that the head is pulled, may as well lap those valves with grinding compound and replace the valve seals. Also keep in mind that you may have to replace some of the valve bucket shims to get the clearances right.
      On the other hand, you MIGHT be able to find a replacement engine that has been tested for compression, that doesn’t burn oil, and fits your bike for much less time and trouble.
      • Fearthepack
        • May 2012
        • 255
        • Orlando, Fla.
        #288
        Thanks Skids.
        Both #3 valves are creaking in the seal when rotating the motor this could be a clue or maybe not. I did lap the valves and new seals on rebuild. Thanks for some direction.
          • 2083
          From what you stated in the previous post:
          "Lets check for compression pulled #1 plug put finger over the hole cranked it over nothing, nothing WTF checked 2,3,4 and nothing. I have no compression at all. Could explain the fuel getting blown out the carb no suction to draw it into the cylinder. "
          Tells us that you have at least bent 4 valves, one in each cylinder, minimum.
          You're getting fuel back through the carbs through the bent intake valves.
          You may not want to rotate the engine as it may cause further damage.
          Pull the head and see what the damage is.
            • 5062
            #290
            Although it could be a possibility to have 4 bent valves, It might not be. If the valves are open during the compression stroke due to chain slip, there may not be bent valves on every cylinder. However, he did say that there was interferrence while turning the crank, so I suspect there will at least be one or two.
              • 5062
              #291
              PS, if valve shim clearances are tight there is more of a chance for valve contact and bent valves....
                • 5062
                #292
                  • 8800
                  I would think the valve clearances would be way larger than normal on bent valves.
                    • 5062
                    #294
                    True, once they are already bent and don't seat properly the shim clearance will be big. I was speaking of possibilities of not having all bent valves if shim adjustments are loose -- however I am not sure that it would prevent valve-to-valve striking...
                    • andreashweiss
                      • 951
                      • 180 mile northwest of Spokane,WA
                      #295
                      valves
                      In case you need some stock used valves/springs/clips/. I have two complete 78E sets left in the parts pile. A set of eight shipped by us priority mail $40, send me a private message if interested , thanx andreas
                        • 5062
                        #296
                        That is a heck of a deal Andreas.
