You do need to get the front bracket above where it mounts to the frame. Much easier with out the carbs in place but still can be done. There are two bolts that mount to the sides of the airbox also (sounds like they are already removed).
a couple carb questions
Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
72 Yamaha Mini JT2 - Youngest Daughter's bike (She wants a bigger one now) -
DeanR,
Is the bottom half of the airbox removed? Just trying to get caught up on what is done so far.
Yeah, don't touch the screws holding the airbox to the bracket, but it's the bolts holding the bracket to the bike that get removed and allow sliding the airbox attached to the bracket rearward. Snorkel can be manipulated, removed or shortened to allow easier sliding rearward.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
Well, just took the carbs back off to position the airbox bracket properly (above the frame tab). Now there is not enough room between all 8 boots to even slide the carb bank back in.
Previously, with the carb boots connected, the air box boots just missed being able to connect up by 1/2 inch at the most. Barely too low.
I need the secret!
Yes the bottom is off and everything is free.80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
Yeah, someone help him! I can't visualize the issue he is having, other than it must be frustrating!Howard
ZRX1200
Ty
72 Yamaha Mini JT2 - Youngest Daughter's bike (She wants a bigger one now)Comment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Time to walk away again...This is ridiculous.
The first minute of that video is the problem. I'm sure his bike and mine are built the same, but I don't seem to have near the same room to work between the two sets of boots that he does. He easily inserts the carb bank from the left (I did that, but surely not that easily) then lowers the carbs into the airbox boots. Unless I'm missing something, mine will not do that.
Other various orders of doing things have also failed to work.80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
Carbs in from left side......check.Time to walk away again...This is ridiculous.
Part way in with carb bank, with other hand hook up throttle cable......check.
At this point, UPPER portion of airbox should ALREADY be resting on engine case(airbox boots below carb venturis.
Spray silicone inside airbox boots, lift airbox up, pulling lips of boots past carb venturis(may have to rotate boots abit) Catch bottom of boot lips on carb venturis then rock up and down while forcing airbox on venturis.
Word of caution.....keep right leg in FRONT of footpeg while forcing forward on airbox. You can see what this can lead to if not! Trying to catch a 680lb.full dresser as it unintentionly rocks off centerstand.......we'll just say it wins
Did you lube up the inside of the rubber tubes on the air box? Also, I usually end up bending the bracket that goes over the frame a little to get some wiggle room. Oh, and you do have JUST THE TOP of the air box installed! it will NOT work well if the air box has the filter and lower cover installed.Ray Matteis
Dean,
Starting with the top photo:
Install the carbs into the holders on the head. Make SURE all 4 are FULLY inserted.
squirt silicon lube into the 4 air box boots
grab the brass colored mount on top of the air box, and pull it back, collapsing the air snorkel against the battery. Keep the bottom rear of the air box close to the engine, so the brass mount is BELOW the mount tab.
You should now have the room needed to install the boots on the rear of the carbs.
Tighten all 8 clamps, and THEN use a large flat pry bar or screw driver to pry the mount back over the top of the tab on the frame.
Let us know....Ray Matteis
My top bracket is bent down out of way, so not an issue.
Just DO NOT remove scews holding bracket to airbox, or you'll be spending some time re-assembling the inards
Ray, old buddy old pal! (I don't know Ray by the way), you nailed it. This picture is more or less where I was at with my first post about this problem. Squishing the snorkel was the tip I needed to get the final bit of travel to attach the airbox boots.Dean,
Let us know....
The second tip I needed was to manhandle the brass bracket with a big screwdriver, after tightening all the boots, to get that bracket above the frame tab where it is supposed to be. (the actual original problem)
Piss poor design.
Thanks everyone. My carbs are not coming off again any time soon.
80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
I ended-up removing my top brackets, and putting RTV and duct tape over those holes. The side mounts secure the box well enough in my view. Those brackets were a pain.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
That top bracket is easily pried over it's mount so the air box can be pushed down for carb removal, then back over the mount to be reinstalled. Done it a hundred times.Greg
. They are ever-so-slightly angled.
