Venturer Rescue
    Originally posted by Eastcoaster
    Thanks for the pictures they are a great example The search is on they would be a nice complement to the bike if I can find them
    IIRC, those are the 52series like in the pics Phil showed. The yellow tags on inner portion of mine that have that number series have decades ago dissapeared.
    Suzy GS's of the 850's and up used the same as did the Kaways. Same in configuration on the smaller inline fours, which just puts the inner edge of lower really close to cyl. fins Doesn't seem to be an issue, as the ones I gave 3Phase for his 80G a few years ago originally came of a GS850.
    You can purchase new well-nuts from Vetter's site if there needed for the holes in fairing, or your local Ace or tru-Valu. Vetters are a heavier duty rubber and pull up tight a little nicer. Same goes for the better quality of windshield screws/nuts from Vetter.
      Yes the headlight brackets are folded in
      The tank measures 4-1/2" to rim
      Big thick plastic pouch with wiring I guess?
      the s/n is 4R1 000602 it's an H for sure
      Yup......undo that bag, remove and unplug, clean and dielectic EVERY connection. Re-install bag(rare to find if wanting it original).
      • TomB
        • 967
        • Cumbria, UK
        You do have the BIG tank. They're easily distinguishable by the curve where your knee rests, the standards have a nice radius curve, the BIG tank radius is kinda stretched upward.
        I'd love a Standard tank, and have loads of Venturer tanks lying around here
        Tom
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Say you have loads of Venturer tanks laying around, once more please !
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            Shipping back and forth to the UK will not be cheap, but it IS Christmas time! No VAT on "presents", so let me know if you really want a standard tank....
            • TomB
              • 967
              • Cumbria, UK
              Yep, they're not strictly Venturer tanks, just the Standard tanks the rest of the world got, they're ten a penny over here, but are the same thing as a Venturer tank.
              I think I have 5 spare but shipping will kill it.
              I use one on my 5K7 Sport for touring
              Tom
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                I can see you in that paint I'd like to see more pics of that bike of yours, looks great from what I can see !
                My new purchase turns out to be a 4R1, I've some questions I'll start another thread.
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • TomB
                  • 967
                  • Cumbria, UK
                  DBS PM sent, don't want to dilute Eastcoasters Venturer thread
                  Tom
                  • Eastcoaster
                    • Jan 2012
                    • 513
                    • oceancity NJ
                    Venturer Runs
                    I got it to start and run. Idles fine but no throttle response at all it bogs and dies. I cleaned the carbs I have seen much worse and did not short cut on the clean. starts fine. If I touch the throttle it dies.
                    I let it warm up 20 minutes no change
                    if I leave the enrichner on it is a little better
                    Could the sync be out enough to cause this?
                    I have done a few others and not had this problem this bad
                    New plugs
                    Fresh gas
                    New fuel lines
                    All pipes hot
                    Any Ideas where to go next?
                    82 XJ1100J
                    81 Venturer
                    • Eastcoaster
                      • Jan 2012
                      • 513
                      • oceancity NJ
                      Air fuel screws are also factory sealed should I open them and try to adjust?
                      Could this be it
                      82 XJ1100J
                      81 Venturer
                      • vedgar
                        • 311
                        • Clarkston, Michigan
                        A must
                        No way can a carb be thoroughly cleaned without removing the mixture screws.
                        79 1100 SF Carmine Red stock
                        85 Honda v65 Magna
                        • Eastcoaster
                          • Jan 2012
                          • 513
                          • oceancity NJ
                          I was afraid of that. The factory seal caps look intimidating. I did not want to damage anything. The carbs look good I really tried to go over everything.I was hoping not to remove the caps but I will.
                          Compression is good on all 4. I guess I can try to sync and see if an improvement if not carb removal again.
                          82 XJ1100J
                          81 Venturer
                          • phatts27
                            • Aug 2012
                            • 189
                            • Clementon, New Jersey
                            Hey Gordon, getting to those screws is pretty easy and well worth it. You'll need a drill, 3/16 bit, sheet metal screw and some vice grips. Bore out the existing hole in the cap a little. The cap is less than 1/4" tall so be careful not to go much deeper than that. Insert the sheet metal screw, making sure it has a good bite on the cap. Now just pull the cap and sheet metal screw off with the vice grips (the cap Is just pressed in). This may take some muscle. This mod is probably the most bang for the buck out there as it only costs a sheet metal screw and it will allow you to get the most from your current setup.
                            81 xs1100 SH
                            81 xs1100 SH (parts)
                            80 suzuki gs550et
                            07 suzuki S40
                            • Eastcoaster
                              • Jan 2012
                              • 513
                              • oceancity NJ
                              No Headlight
                              I got this Venturer running really well. All along when it barely ran no electrical issues at all headlight came right on
                              Now No headlight No gauge lights and No front running lights.
                              Rear light is on and turn signals work
                              I am Frustrated I was hoping it was a fuse but no easy solution.
                              Anyone have any Ideas on where to start or common problems?
                              I am not even sure if the front running lights are only on at start or all the time the key is on.
                              82 XJ1100J
                              81 Venturer
                                On the Venturer, key on, front running lites and tail lite is on
                                Check the fairing plugin for looseness or dirty pin connections. For that matter, as this point, to reduce any frustration, unplug, clean(Deoxit or spray electrical cleaner) ALL connections, including those located in the 'bag' between the tripple clamp. Remove right sidecover, unscrew mounting plate fuse panel is attached to and unplug and clean ALL the five connections behind there. A little dob of dielectic grease on each connection before plugging back in will eliminate future corrosion on connections.
