Venturer Rescue
  • Eastcoaster
    • Jan 2012
    • 513
    • oceancity NJ
    Venturer Rescue
    I am just starting on the work to the Venturer I picked up Saturday. I got the bike for 600. The bike was in much better condition than it looked in the pictures. I was told the handlebar was bent so assumed it was dropped.
    I was wrong it was about ripped off. But it was done during a shipping and no damage to anything but the bar. The bike has no road rash and is clean.
    The chrome and plastics are great faring excellent and the saddle bags not a mark. Even the lock chain is still there. I was hoping to find the tire wire but it was not.
    Other than the normal things for a bike sitting since 07 it is in amazing shape and I hope to get it running in a few days. There are a few things I am unfamiliar with and need some help. Not that they are important to get it going but I am curious.
    On the lower left side of the fairing looks like there was a switch but it has 2 small wires that look like they are connected to a radio plug?
    On the faring it looks like it had lower faring pieces? Are they easy to find? I saw a set on ebay but how do you know if they fit?
    The seat has a split is this repairable or is there a good source for a replacement cover?
    82 XJ1100J
    81 Venturer
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Seat could be repaired (for how long ?). Unhook it, get up under it with duct tape, pull it together and then use tent sealer to carefully re-attach the seams.
    The switch hole you can use for whatever.
    The lowers will be a bit harder to find, brand specific but maybe others could be made to fit.
    Side note, just picked up a bike with fairing and the lowers came with. The owner mentioned in cold weather the lowers were fine in hot like a furnace directing the engine heat right on the legs.
    Bike sure is purdy !
    Just heard today in 81 there was an SH, LH, H, and H Venturer.
    Believe it or ?
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      Hi Gordon,
      Yes you are missing the fairing lowers. Thes fairing was made by Vetter for Yamaha. i suspect Vetter lowers and Yamaha lowers will both fit.
      On mine there is a cigarette style 12V outlet on the left.
      You do not need the tire wire as those are Special exhausts and the axel will slip out past them with no trouble. I find it easier to remove the right side bag when changing the wheel but you do not have to.
      Well done it looks like a fine example. I can take pictures of my lowers which are off at this time if you need to compare.
      • Eastcoaster
        • Jan 2012
        • 513
        • oceancity NJ
        Lowers
        A picture of the lowers would be great. The ones I saw on ebay were pacifico xs1100? or at least that's what they said I was way off.
        http://www.ebay.com/itm/251686650648...%3AMEBIDX%3AIT
        Thanks
        Gordon
        82 XJ1100J
        81 Venturer
          Thanks
          Gordon
          Hi Gordon,
          Those are NOT what you need. Not sure what they fit either. I'll try and get some pictures to morrow.
            Believe it or ?
            Nope........just three........The 81H is the Venturer.
              Hi Gordon,
              You are in luck. I had soem pictures already. Note Venturer was marketed as Trans Canada here.
              Hope this helps you find the ones that will fit.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                I was told the H could be had with or without the Venturer package ?
                Is that true ?
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • Briggs&Stratton
                  • Mar 2014
                  • 47
                  • Grand Forks, ND.
                  Great find! Hope you keep us updated as you get it running.
                  79 SF
                  IG "9mmHeater"
                  • Aches n Pains
                    • 349
                    • Reston, Va.
                    Man, your wife is a saint. How many does that make now?
                    1995 KZ100P
                    Pods, jets, pipes, cam adjuster, oil cooler
                    1977 Ironhead - custom build
                    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      What she don't know can't hurt me !
                      Anyone know the best way to tell if this is an H ? T.I.A. Don'e
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                        Serial number will tell you what model you have. The lowers on EBay ARE for the '78, EARLY '79 Pacifico fairing. They ONLY fit those rare fairings. I didn't know they were made of gold, though... The Venturer has the 6 gallon tank, and you can tell from the badges and the height of the tank at the filler. The standard is about 1" from the top of the tunnel to the top of the tank, the venturer is about 1 3/4".
                        • Eastcoaster
                          • Jan 2012
                          • 513
                          • oceancity NJ
                          Lower Fairings
                          Thanks for the pictures they are a great example The search is on they would be a nice complement to the bike if I can find them
                          82 XJ1100J
                          81 Venturer
                            Is that true ?
                            No, but some came with the front signal stalks(unless dealer shelved them), and the chrome fork covers that hold headlite are already there folded inward. That way, you could 'strip' it and legally ride it,..... plug'n'play.
                            • Eastcoaster
                              • Jan 2012
                              • 513
                              • oceancity NJ
                              It's an H
                              Yes the headlight brackets are folded in
                              The tank measures 4-1/2" to rim
                              Big thick plastic pouch with wiring I guess?
                              the s/n is 4R1 000602 it's an H for sure
                              82 XJ1100J
                              81 Venturer
