clutch....
    • 9980
    Personally I could guess pretty close because I'm in that sort of business but I wouldn't advise you to do that.
    Do you have a neighbor, a friend, or a parts house where you could borrow one.
    I know O'Reilly's loans tools.
    • Jeffintampa
      • Apr 2011
      • 344
      • Zephyrhills, Florida
      I will have to make a few calls
      Thanks again all
      Bike History:1980 XS 1100 special current bike
      1980 XS 850 special wife sold
        Hi Jeff,
        7.5 x 12 = 90 INCH /Pounds
        you might find an inch/lb wrench available.
        Cheap enough at Harbor Freight.
          • 8862
          You can tighten them with a 1/4" drive rarchet, you can't really overtighten them that way.
          • Jeffintampa
            • Apr 2011
            • 344
            #35
            Thanks
            Yea I got one from a friend set it at 90 and think it slightly bent one of the parts back till it clicked, so I took it off bent it back and set them all just a tad of a grunt with a 1/4 inch drive.
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              #36
              Hi Jeff,
              They are now on sale for $11.99. 1/4, 3/8/ 1/2 inch drive, all the same price with a super coupon.
              Call 1-800-423-2567 and ask for the coupon
              Good while supplies last.
              • Jeffintampa
                • Apr 2011
                • 344
                #37
                Perfect
                Originally posted by BA80
                Get rid of the 10-30 synthetic and get a jug of Super Tech 20-50 plain old dyno, order some new BARNETTS, get it adjusted properly and you'll have a new bike.
                Guaranteed.
                BTW......whatever oil you use be sure the API Service label looks like this, blank at the bottom.
                Thats what I did seems to work good, might have to do a little adjustment seems I need a tad more clutch as the gears are to close to the full squeeze on the handle, I put a new cable on also. This means I need to lossen the 12mm nut and clockwize the screw a bit correct
                  #38
                  Hey Jeff,
                  How much slack do you have in the lever...in other words, how far will the lever travel BEFORE you feel resistance to the lever/cable? If there's more than a 1/4 inch of gap at the end of the lever near the hinge, then you may first want to try taking up some of the cable slack with the cable adjuster at the handle first. IF you set the engine screw too tight, then it can cause slippage because the plates won't fully engage...will be held slightly apart.
                  If you don't have much slack in the cable, then it does sound like you might need to do the adjustment at the engine with a little more CW rotation of the center screw.
                  • Jeffintampa
                    • Apr 2011
                    • 344
                    #39
                    Thanks Top Cat
                    Hey Jeff,
                    I had a tad of slack at the handle, I loosened it up a tad more and put about a quarter turn on the center screw, seems to be better. Just a tad more I think will be perfect. but.....no 5 gear slippage.....yea
