Sorry running out of time
    • 8962
    Try bypassing the headlight relay, unplug it and jump the red/yel and the blu/blk in the harness plug and see if the HL comes on with the key on.
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      Did that and it does come on, bad relay?
      I tried a different relay before and it did not work, could both be bad?
      BAMN!
      '81 XS1100H "Brutus"
        • 8962
        Your bike is an 81, there is a diode in the harness in line with one of the white wires from the alt which could be bad. The yel wire shouldn't do anything on your 81, it was used in the 78-79 bikes with a different type relay and was omitted on the later models though it is still there. Check for AC voltage at the white wire at the relay when the bike is running. If you want to check the relay, open it up and look for a bad solder joint.
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          #34
          One relay reads 14. and above the other jumps between the 30's and 70's.
          both cases no light.
          How do you open relay w/o wrecking it?
          BAMN!
            • 8962
            I've only opened the 79 type, the metal nearest the plug can be pried back and the guts will pop out, not sure on the 80-81 type, maybe someone will chime in about that. It is safe to leave the relay bypassed permanently if you choose, many people do.
            • Nubian
              • Apr 2011
              • 467
              • The Big East
              #36
              Got it opened and saw a broken solder joint. Thanks again. Will advise
              BAMN!
              • Nubian
                • Apr 2011
                • 467
                • The Big East
                #37
                I will bypass for now, until replaced, I mostly prefer original configuration above all. Do I remove the relay or leave plugged in while jumping those wires?
                BAMN!
                  • 8962
                  Unplug the relay, and jump the wires in the harness plug and wrap with electrical tape.
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    #39
                    Done.
                    Back to carb issues later today after road trip.
                    Btw has anyone found the location of that diode in the harness?
                    BAMN!
                    • Nubian
                      • Apr 2011
                      • 467
                      • The Big East
                      #40
                      I may be on to something, there is a white label on the harness just above and forward of the battery on the right side of the frame. Diode location? Would they be so kind? Got to run will post pictures later during USA win over belwhatever
                      BAMN!
                        • 8962
                        Here is Scott's writeup on the diode repair...
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          #42
                          I believe this to be the location of the diode, will investigate to verify, man I hate having to slice my harness up. Since I do not trust my soldering skills I have an OEM HL relay on the way. I have pulled and tugged from that spot so many times over the years, if I only knew
                          BAMN!
                          • Nubian
                            • Apr 2011
                            • 467
                            • The Big East
                            #43
                            Not so sure now is it broken? Are those two points supposed to be connected? There were no loose pieces inside and nothing fell out.
                            I should have taken a pix of the other side,where there was connection between these two points. So in my infinite wisdom I soldered them up and re connected, blew the fuse twice. More pix's coming......
                            BAMN!
                            • Nubian
                              • Apr 2011
                              • 467
                              • The Big East
                              #44
                              Before above, after below:
                              The opposite side which led me to believe there was a broken link
                              BAMN!
                                #45
                                Hey Dude,
                                Yep, you made a direct SHORT by soldering those two "U" shaped peices of metal together! If you looked closer at the one on the left, there is a small wire that goes to that large coil. I'm not positive but I would expect the other "U" shaped piece is connected to the harness prongs that go to ground! If you look at the flat pieces on the RIGHT SIDE as shown in that picture, you'll see that they MOVE to make or break a connection between the static and moving part....likes the POINTS in an old points/ignition piece. Those contact can either corrode, or build up burned pits in the surface that prevents the electricity from flowing thru it. A thin fine file or folded piece of sandpaper/emory cloth can recondition those contacts.
                                Then you can test it by applying a 12 volt current to the connector prongs that go thru the large coil to see if the relay will throw. You can also test the other 2 connector prongs with a meter and just PUSH the lever like the magnetic coil would do when/if were energized together and ensure you have continuity. If both work, then the relay is probably good, and like you've possibly figured out by now that the DIODE has gone bad, and will probably have to cut into your harness afterall!
