Foot Peg Rubber upgrade
  • Tmycal
    • Feb 2014
    • 17
    • Los Angeles, CA.
    You've done a pretty good job...so far. Now, make it perform. You'll need some better, longer shocks. New springs up front, maybe straight rate with emulators. You definitely need a fork brace. Leave it like it is, and this friend of mine is going to have you for breakfast. (He may do it anyway)
    Is this the fork brace you gents have on your bikes?
    80 G
      Wow! That is expensive! Get a Tkat brace for about $100.
      • Tmycal
        • Feb 2014
        • 17
        • Los Angeles, CA.
        $90 more for pretty . . . .I'll really need to debate this one. . .
        80 G
        • Yahman
          • Mar 2008
          • 779
          • Salem, OR
          That's a TKAT brace in the photo of Marty, they shine up real nice with a bit of buffer work. Actually, every bike in that photo has a TKAT brace on it.
          82 XJ1100
          80 XS1100G (Project bike)
          64 Yamaha YA-6
          77 Suzuki TS-185
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            Don't know if this is true for the XS, but the XJ main pegs are held in place with a rivit. I ground off the bottom end to remove the OEM pegs.
            I mounted mini-floorboards on the XJ but also tried foot pegs from a Honda GL1500 which are wider and softer than the Yamaha units. These were quite comfortable but I went with the mini-boards as they dropped the foot location down a bit, more comfortable for me during long rides. I used a SS metric bolt to replace the OEM rivit. I don't recall having to mod the Honda foot pegs to make them fit but it has been years since I played with them. I do recall the the XJ's peg bracket can be adjusted a bit up or down by loosening the bold that holds them in place and I used this feature to get a better (more comfortable) angle on the pegs.
            There are a bunch of after-market GL 1500 pegs that maybe could be adapted to an XS or XJ as well.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
              • 7943
              http://www.ebay.com/itm/Fork-Brace-M...item3a806cea6b
              With this, you can put the fender back on. Tkat's fork brace assembly for the Yamaha XS
                • 7943
                Photo is JeffH, my identical cousin.
                This is me.
                Tarozzi makes a brace for the XS11 as well. Its function is similar to TKAT.
                Fast From the Past deals in them.
                • James England
                  • 3039
                  • North of England
                  Thank you for the response. You're way out in England! I may be PMing you in the near future depending on how desperate I get. I was really looking for an upgrade, something different than OEM. If I don't find another solution, I'll hit you up.
                  Thanks Again.
                  No problem. England isn't so way out though, as many recipients of wheel bearings will testify!
                  • James England
                    • 3039
                    • North of England
                    What you may want to do is go with the European foot peg position. It is moved back a bit. See some of James England's posts for more info and help with that.
                    Yep. And I have a full conversion set available too!
                      • 5062
                      Here is my bike . . . sure I'm sure I'll get critiqued on it,
                      My ass hurts just looking at that seat!
                        • 9980
                        Ha ha ha ha ha ha.............Jeff with his chicken wire headlight.
                        • James England
                          • 3039
                          • North of England
                          Awesome! Thanks a bunch for the help. I had been searching for a fork brace too since I have no front fender and those forks IMO are a tad undersized for such a heavy bike.
                          That big brace looks a bit agricultural, IMO. I'd shop around for a used vintage one myself. They come up on eBay regularly. The Micron ones usually go for about $75 although I see that new replicas are now available...
                          Yes, the forks are weedy for such a big bike. We've had different opinions on the merits of using a fork brace but I've always fitted one to every XS1100 I've ever had and always found they make a big difference.
                          • James England
                            • 3039
                            • North of England
                            Why would anyone keep poultry on a motorbike?
                              • 7943
                              It has a fairing on it now. The chicken wire was short lived.
                                • 7943
                                The big brace is popular with the motorcycle hipsters. James, you're out of touch.
