I can't get my carb's tuned properly with exhaust and pods. ):
  • Dylano*
    replied
    And if you guys have shims that would be awesome.
    I'd make it worth your while.
    This weekend, I will re-measure all the valve clearances,
    and maybe make a tool to check my shims.
    Leave a comment:
  • Dylano*
    replied
    Originally posted by 3Phase
    Nope, there's nothing wrong with the way you want to do in my book either!
    Bear in mind that all this stuff can be and usually is cumulative. You may wind up doing several carb syncs; pulling the carbs to clean them; play with the fuel levels and re-jetting several times to work around tight valve clearances and a wonky ignition and/or electrical problem.
    Finally! It's sync'd up and running! You've got a set of monscuceous main jets in that bad boy that'd do a Chrysler 440 Hemi proud so you jump on and ride out to see just exactly what it'll do. Holy Moly! Aside from a few pops and snorts in the low and midrange it hits 5K RPM and pulls like a freight train right up to and over the ton before you know it!
    How are the brakes?
    Ahhhh yes the breaks,
    The fronts weren't all there to begin with,
    so I got an after market lever and reservoir.
    I got good pressure,
    but I have to squeeze the hell out of it with minuscule results!
    The rear breaks... they are kinda locked up,
    basically on all the time,
    BUT I can make them MORE on by pressing the lever!
    I end up stopping, just slowly... haha
    Luckily this thing has so much damn torque, that downshifting works wonders!
    Leave a comment:
  • Dylano*
    replied
    Originally posted by BA80
    The advise I usually give anyone that's going to try to build a custom bike is, get it running good with the stock components FIRST. It will run good with the carbs set up stock no matter what you do to it if the carbs and ignition are right.
    Then you can take little steps one at a time to try to improve on it.
    I would normally agree with that...
    BUT I bought this bike in a pile of parts, well a few piles actually.
    Most of it was there, but rather than build it stock first,
    I decided to just build it how I want it to begin with.
    Even if it is harder to get running,
    I was hoping that this way it would be running and built the way I want it, sooner.
    That was the goal anyways! (:
    Leave a comment:
    replied
    It's like a rerun of, "Officer and A Gentleman" ...
    He wants to get jets!
    I've got some spare shims too; gleeped one from the wrecked XJ11 head that's sitting in the corner and fixed the tight exhaust valve that showed up this time around in the valve check.
    Brakes.
    Leave a comment:
    replied
    Greg, I think he's going to take the high, winding, twisty route just for the fun and the leaning <sic> experience: Kinesthesia -- he'll do alright.
    Brakes?
    Scott, as I remember, the XJ had linked brakes, so he will be able to push on the pedal, try the hand lever, and come to a stop.......eventually. Then, when he tries to start on the next great road, the rotors will be smoking HOT! We've been there, done that.
    As long as he STARTS with a valve adjustment, the rest should go well.
    Dylano*, I do have a few shims, so I may be able to send down the correct size once you know what you need.
    Leave a comment:
    replied
    Brakes?
    Brakes?
    Leave a comment:
    replied
    Leave a comment:
    replied
    Go for it!
    How are the brakes?
    Leave a comment:
  • Dylano*
    replied
    Do ONE thing at a time Dylan, that way if it isn't right your not wondering which change caused it.
    Of course! Good advise I tryy to follow!
    Leave a comment:
    replied
    Originally posted by Dylano*
    But I would be doing in the order suggested wouldn't I?
    I'll do the order suggested, just sync and rejet BEFORE as well...
    I don't see what harm that could do.
    I will sync and rejet to get it actually running somewhat decently(hopefully) then follow the suggested steps
    Nothin' wring with that in my book!
    Leave a comment:
  • Dylano*
    replied
    Originally posted by motoman
    Patience grasshopper........in order, as Scott explained IS your best choice.
    Us oldies' here can guess with farly good accuracy what's gonna happen, and in what order it's gonna take place if NOT following those sound suggestions.
    Leave a comment:
  • Dylano*
    replied
    I bought a starter kit from somewhere, don't recall now, and paid like $100 for the shims in an organizer box. I think there were 20 shims. I've been adding from my parts engines as I tear them down.
    I was trying to do kind of a shim library thing but a couple of people didn't send the ones they took out back to me when I sent what they needed to replenish the stock so I quit.
    Yeah I saw a couple deals similar to that.
    That a good idea... of course, leave it to the few to spoil it for the many! (:
    Leave a comment:
    replied
    us oldies' here can guess with fairly good accuracy what's gonna happen, and in what order it's gonna take place if not following those sound suggestions.
    +1.... Lolol.....
    Leave a comment:
    replied
    Leave a comment:
    replied
    Yes I agree, $120 saved is worth it... IF they would both be done in at the same time... BUT I'd gladly spend $120 if that means I can ride the bike and call it mostly DONE a week sooner..
    I've been building this bike for quite some time now, and getting it running great is the last step before ...taking it apart again to clean everything up better haha
    But really... I got everything rigged 90% and just want to make it run good and ride-able. THEN I will take apart one section at a time (triple tree/side panels/etc. to bead blast and paint.) Each of those things only taking a day and the bike still being a now ride-able project!
    That's the goal anyways.
    I'll probably end up doing the valves myself, but man, I just wanna ride the thing!
    P.S. of course it's a contest, and YES you are winning! haha
    Leave a comment:
