Ignition
If that were the case, both circuits would likely be history. As mentioned, jumping off with another 12 volt battery will do no harm.
Welding, on the other hand, on these bikes could take out the ignition module. Simply remove the battery ground cable if you do plan to weld. Better yet, remove both battery cables and take the battery out.
[/IMG]
[/IMG]
