XS11 Cylinders 2&3 not firing
  • visago22
    • Apr 2014
    • 11
    • Raleigh, NC.
    Hey guys,
    This is my first post here so, Hello.
    I have something of a project bike in a 79 xs11sf.
    I am getting spark in 1&4 but not in 2&3. I switched the coil wires and got spark on 2&3 so i know the coil works. so that leaves just the ignition module ...right?
    Also...what size are the bolts holding the exhaust in place?
    78 E
    • 4015
    The pick-up coils as well I believe. I've read some have found broken solder joints inside the TCI.
    • mack
      • 2411
      • Ontario, Canada
      coils
      There are two coils. One for 1 + 4, and one for 2 + 3. Sounds like your 2/3 coil is toast. Or at least the wires from the coil or plug caps from same need investigation.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • MPittma100
        • Aug 2011
        • 2359
        Not Firing
        Check the pick up coil wires for broken spots. Check all 4 wires for both pick ups. Gently stretch the wires in order to locate a break within the wire(s). Note that the wire can be broken inside of the insulation.
        When/if you find one broken, do a search on this forum for the repair procedure.
        Mike
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          Mike
          +1 on this. It's the MOST common issue in this situation.
          • Prisoner6
            • Aug 2013
            • 1184
            • Phoenix, AZ
            WELCOME to the forums, Dave!
            Here is the link to the pick-up coil wire repair:
            Marco
            1979 Honda CBX
            2002 Kawasaki ZRX1200R
            WE MISS YOU, DON
              Grab these
              one out the two are probably good. For the price you should take the chance.
              http://www.ebay.com/itm/Yamaha-XS110...8ac8ec&vxp=mtr
              • visago22
                • Apr 2014
                • 11
                • Raleigh, NC.
                I dont beleive the coils are the problem...I hooked the 1&4 wire to the 2&3 coil and got spark so wouldnt that rule out the coil??
                I will take that cover off tonight and check the wires in there for breaks.
                what size is that allen head??
                78 E
                  .......5mm.......
                  • CaptonZap
                    • Jun 2010
                    • 1748
                    • Denver
                    [QUOTE=visago22;437421]I dont beleive the coils are the problem...I hooked the 1&4 wire to the 2&3 coil and got spark so wouldnt that rule out the coil??
                    [QUOTE]
                    Yep, if you swapped the grey and orange wires to the coils, and 2&3 fired, the coils are good.
                    As the guys said, check the pickup wires under the left side engine cover.
                    A preliminary check can be done at the four prong plug at the TCI. The top two terminals in the wiring plug are one pickup, and the bottom two are the other, Put a continuity checker across the top two, and check for continuity. Then the bottom two. If my calculations are correct, it will be the top two that do not show continuity.
                    CZ
                    • visago22
                      • Apr 2014
                      • 11
                      • Raleigh, NC.
                      i checked under the left side cover and the two wires seem to be in ok shape...didnt see and rubber banding when tugging slightly.
                      guess i will check continuity at the ignition module now
                      78 E
                      • visago22
                        • Apr 2014
                        • 11
                        • Raleigh, NC.
                        could the ignition be wasted from the previous owner jumping the bike with his car?
                        78 E
                          There should be 4 wires
                            A car is the same voltage as the bike. it won't hurt it a bit.
                            • Prisoner6
                              • Aug 2013
                              • 1184
                              • Phoenix, AZ
                              As Greg (BA80) said in post #13, there are 4 pick-up wires ... make sure they are all good ...
                              Marco
                              1979 Honda CBX
                              WE MISS YOU, DON
