XS11 Cylinders 2&3 not firing
  • MPittma100
    • Aug 2011
    • 2359
    Ignition
    Originally posted by visago22
    could the ignition be wasted from the previous owner jumping the bike with his car?
    If that were the case, both circuits would likely be history. As mentioned, jumping off with another 12 volt battery will do no harm.
    Welding, on the other hand, on these bikes could take out the ignition module. Simply remove the battery ground cable if you do plan to weld. Better yet, remove both battery cables and take the battery out.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      i checked under the left side cover and the two wires seem to be in ok shape...didnt see and rubber banding when tugging slightly...
      You need to tug aggressively on those wires, not 'slightly'. If you can pull one of those wires apart with the pull between your thumb and first finger, it was broken or down to only a couple of strands or copper anyways.
      Think of how much force it would take to pull apart a fresh piece of wire that gauge, and whether you could even do it with two hands. Probably not. Now think how much less force you can pull with two fingers, and you'll see you can actually be quite aggressive when you do this procedure.
      • visago22
        • Apr 2014
        • 11
        • Raleigh, NC.
        i started the bike and pulled on all 4 wires and nothing really changed as far as the idle..when i tilted that whole assembly forward it did pick up the pace in the idle, but it seemed like a vacuum advance as the exhaust pipes were still not getting hot.
        i dont suppose someone has a spare ignition module laying around huh?
        78 E
          Have you checked continuity yet in the 4 pickup coil wires yet?
            Continuity and check the Ohm reading on the wires.
            • visago22
              • Apr 2014
              • 11
              • Raleigh, NC.
              ok ...just to make sure we are on the same page....i am checking the right plug here on this
              [IMG][/IMG]
              this is my meter...what settings do i use? (electrical idiot)
              [IMG][/IMG]
              78 E
                • 4012
                Turn that dial to Rx100 (resistance). You will hopefully see a dime or less between one end and the other of the wire.
                • visago22
                  • Apr 2014
                  • 11
                  • Raleigh, NC.
                  top 2 wires read 7 on Rx100...is that about right??
                  78 E
                  • visago22
                    • Apr 2014
                    • 11
                    • Raleigh, NC.
                    bottom two is 7 as well
                    78 E
                        That should be within range.
                        If no one closer has a TCI I have a couple.
                        But before we do that, find the plug behind the fuse panel where the pickup coils plug into the harness. Unplug it and make sure it's not corroded up. Pack some dielectric grease in there when you plug it back and it'll save you dropping cylinders if you get caught in a down pour.
                        • visago22
                          • Apr 2014
                          • 11
                          • Raleigh, NC.
                          Guys...first of all, thank you for all the advice and knowledge...this being my first XS, i am still dumb to all the nuances of this pup.
                          So i have been outside unplugging things and replugging things, checking spark and swapping wires...and i tried to start it...and it worked....suddenly its popping on the right side pipe and i can feel heat...holy crap, its working, after a few minutes of revving and annoying neighbors, the popping stopped and i rode it down the street, thats a fun little bike, i forgot about the acceleration of a japanese bike!!! Now i just need some rear brakes, lol.
                          78 E
                            Cool. I just noticed I quoted one of your posts and one of mine, I meant to quote both of yours with the ohm readings.
                            • CaptonZap
                              • Jun 2010
                              • 1748
                              • Denver
                              Plugs, huh?
                              CZ
                                Sounds like the plug behind the fuse panel was either corroded or wet.
