Potential new project
  • James England
    replied
    Carb bits
    I'm looking for four of the plastic covers that go on top of the mixture screws on the carbs... They are usually white or yellowish with age and they push on top of the four mixture screws at the front of the carbs, just near the inlet manifolds. Can anyone sell me some please? Or I could do a nice deal on a couple of rear left side wheel bearings as a swap
    Leave a comment:
  • James England
    replied
    Originally posted by Aches n Pains
    Damn, that's a pretty bike.
    Thanks. This current project should come out looking like the complete bike in the pix. Probably a little bit better. I'm waiting for the tank and panels to come back from the sprayshop and should have them in about ten days. So, hopefully I'll be posting pix of the completed project very soon!
    The last bike I did is actually up for sale, I discover yesterday.... http://www.carandclassic.co.uk/car/C440211
    Leave a comment:
  • Aches n Pains
    replied
    Leave a comment:
  • James England
    replied
    Mirrors
    Hi Folks
    I found some mirrors which closely match the oem ones that came on the European models. They are not expensive either.... I got them on eBay...
    Here's a link to the seller. He's in Germany...
    http://www.ebay.co.uk/itm/3102883006...%3AMEBIDX%3AIT
    One other point...I upgraded my remote fuel tank from an empty oil container to a luxurious grass mower tank. It really is ideal for tuning the bike...no fuel tank propped up to get at the adjustment screws and get damaged. It makes life much easier (and a lot safer) when syncing or testing carbs for leaks etc. I ran a single piece of pipe to a T-piece. The tank cost me $1 on eBay!
    Leave a comment:
  • James England
    replied
    Viton update
    Just a quickie to say that the Viton chunks I used between the cooling fins are absolutely fine, even with a really hot engine. There's no sign of shrinkage, or melting or anything untoward........
    Leave a comment:
  • James England
    replied
    James if I may please ? Small bits were sent with the frame for powder, like triple tree, center/side stand, switch gear, headlight, gauge covers, foot pegs, mid/FD, etc. ?
    How much beside engine is done with VHT ?
    I take it then that the VHT is durable enough for normal abuses and possible minor fuel/oil spills ?
    I put together a VHT kit to do an exhaust consisting of 2K° flat blk and clear, looks good on my sample I now have a couple exhaust sets rough enough to use it on.
    Are you using the standard gloss blk VHT ?
    Sorry I ask so much, prying into your methods but I'm compelled by the artistry of your work !!!!!
    TIA Don'e
    heck, Done, none of it's a secret. I only sent the frame, swing arm, battery holder, rear fender brace, stands and a few other bits for powder coating. The triple tree is black xylene paint and the switch gear is PJ1, although next time I'll use VHT instead as PJ1 in Europe has been emasculated chemically! Gauge covers are VHT.
    The VHT dries in a few hours but it has to be cured at 100c for an hour and then acquires resistance to chemicals etc over the next few weeks. It is OK for minor spills althoughI tested a bit by dunking it in gasoline.....it came off! But, in normal use it's fine.
    For you in the USA, PJ1 Satin black case paint is where it's at. You still have the old, unadulterated formula which is brilliant. I spoke with PJ himself earlier this year,as he phoned me from the USA to confirm that the EU had banned his product and that it had been changed to something inferior. He actually admitted it and said how sorry he was. But, for now, you have the proper stuff jb the USA. I would use that if I could get it as it is 99.9% like OEM and nothing shifts it...
    Leave a comment:
  • donebysunday
    replied
    Yes done, I sent the frame for powder coating. I soda blasted the engine and used black VHT enamel.......
    TIA Don'e
    Leave a comment:
  • James England
    replied
    Originally posted by Prisoner6
    The "PROJECT" is sounding great to me, James ...
    Good job!
    Thanks, Marco. The sound on the vids is deceiving. The engine actually sounds exactly as it should.....
    Leave a comment:
  • James England
    replied
    What a cracking motor!!!
    What is that ring on the side of the rear fender under the rear seat cowl? Registration or road tags?
    Thanks. it's a road tax disc. They were got rid of this year, so no more bikes marred by that thing!
    Leave a comment:
  • James England
    replied
    Sorry James, I just have to ask,,,,,,, did you send the frame out for powder ?
    Was the engine also powdered ? TIA ! Don'e
    Leave a comment:
    replied
    Stunning Work James!!!
    Leave a comment:
  • Prisoner6
    replied
    Here they are again... hopefully working this time..... I have to keep them short as the iPad won't send bigger files...
    This first one is a cold start with the choke on first position
    This one shows the choke taken off and normal running....
    Good job!
    Leave a comment:
  • donebysunday
    replied
    Leave a comment:
  • James England
    replied
    second attempt
    Leave a comment:
  • James England
    replied
    First attempt at uploading a video
    Here's my first attempt at uploading a video.......... video taken with an iPad...bike inside workshop......
    Oops a few problems... back with another in a minute
    Leave a comment:
