Potential new project
    replied
    And for some of those who might not know this, zinc plating is otherwise known as galvanization. http://en.wikipedia.org/wiki/Galvanization
    Leave a comment:
  • James England
    replied
    Originally posted by xs650man
    Looking good James ! I like your home zinc set-up, is it something you put together or is it a kit you can buy over there ? My last project I got all the fasteners gold zinc plated and looked very cool.
    I got it from eBay http://www.ebay.co.uk/itm/2514745201...84.m1497.l2648
    The kit is mainly dry ingredients which you mix with demineralised water. It comes with two passivators..one bright and the other a goldy-yellow colour. You basically de rust the components, then degrease and final acid bath before plating. As with painting, the better the preparation, the better the results. I wore one kit out doing two bikes. The electrolyte gradually gets contaminated and the zinc anodes wear away, although they can be replaced once before the elctrolyte becomes too bad.
    The power supply is a normal car battery charger and the kit has a primitive variable resistor to vary the current depending on how much is being plated.
    All in all, it's quite an easy process and the results are impressive considering what the kit costs and the fact that it's a home-done process. Also, it's gratifying to see a manky old component saves and turned into a shiny, non-rusting part.
    Leave a comment:
  • xs650man
    replied
    Leave a comment:
  • James England
    replied
    Update
    Got the frame, swing arm and other bits powder coated....
    I spent the afternoon with a small zinc plating kit....heres a few bits in the tank
    Results were very good with the parts bright and shiny and the zinc plating 'passivated' which keeps them nice and shiny.....here are the carb bits..
    I also did a few other bits..cable holder, headstock nuts, engine mountings and a brake pipe clamps etc...
    I received four carb kits...just the needle valves and seats and float bowl gaskets. A packing error in Japan meant that three of the four needle seat washers were the wrong diameter! So I could only fully assemble one carb! A pain but these things happen and they are sending me three correct replacements......
    Onwards and upwards
    Leave a comment:
  • James England
    replied
    That's pretty far...... Although the teardown is generally the easy part...
    Yeah...the easy bit!
    Leave a comment:
    replied
    I've managed to get this far.....
    Leave a comment:
  • James England
    replied
    Originally posted by Schming
    Nice tip on the races, James
    First time I've seen a rear steer Go-Kart
    yes, we got it to 130mph but the handling didn't feel right...
    Leave a comment:
    replied
    Leave a comment:
  • James England
    replied
    Quick update
    Amazingly, the only OEM parts missing from the bike are the front cable clamp and one ignition coil which has been replaced with one from another bike, also the lift handle. Everything else, including all the little expensive things, are all there. That's quite reassuring.
    The frame and swing arm will be going to the powder coaters next week.....
    Onwards and upwards!
    The steering head beating races were worn enough to warrant getting them out and not doing the tempting little cheat of leaving the races in the steering head. I used a small, primitive stock welder and welded an old bolt across each race. The heat from the welder helps and then a whack on the bolt from the opposite side with a metal rod popped them right out....
    Leave a comment:
    replied
    All the better!
    Leave a comment:
  • James England
    replied
    James, looking at that exhaust it may be worth your trouble to have your local 'exhaust fabricator' fit a crossover between the two sides like the OEM exhaust. Worth a bit of power and should quiet it some too... just a thought...
    There's actually a crossover on the exhaust, Steve... Not visible in the pix.....
    Leave a comment:
    replied
    Leave a comment:
    replied
    Finally, here's a budding XSive...light of my life..... (The boy, not the bike)
    That seat was made just for him!
    From the pictures, it looks like you have a good one.
    Leave a comment:
    replied
    I bet that blue looks great in the sun!
    Leave a comment:
    replied
    Very nice starting point; every one I've bought used looked far worse than that...
    Definitely has/had a fuel mixture issue on 3/4 judging by how discolored the right side exhaust is. And I still like those shorter pipes, gives the bike a bit less 'formal' look, more 'sporty'...
    Leave a comment:
