Carb help!
I have to disagree with this one. Only because I just did this in December and I broke out the tower prying on the stupid thing. MY suggestion is to drill them out. Use progressively larger bits. Mark the depth on the bit so you do not make contact with the screw inside there. When you get about 3/4 the dia of the plug, it should spin on the bit. Then you can pull it out easily.Life is what happens while your planning everything else!
78 XS750Comment
Do this. That screw technique will cause you to break off a tower and it makes the carbs look like crap. If you have access to a drill press, go get some pilot bits and progressively larger reamers (as they have a flat head to them so it will bore through the cap and not overshoot to the top of your screw thus damaging the threads). That is what I did and it worked out great but it did take quite a bit of time because I was being extra careful.I have to disagree with this one. Only because I just did this in December and I broke out the tower prying on the stupid thing. MY suggestion is to drill them out. Use progressively larger bits. Mark the depth on the bit so you do not make contact with the screw inside there. When you get about 3/4 the dia of the plug, it should spin on the bit. Then you can pull it out easily.78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
"May my tires not fail me, nor my engine grow cold"Comment
The same thing happened to me. The broken piece was above the idle screws so it really didn't matter unless you wanted to put some sort of seal above those. That metal is soft AND brittle. I am sure that I don't have the mechanic's touch like Steve has.I have to disagree with this one. Only because I just did this in December and I broke out the tower prying on the stupid thing. MY suggestion is to drill them out. Use progressively larger bits. Mark the depth on the bit so you do not make contact with the screw inside there. When you get about 3/4 the dia of the plug, it should spin on the bit. Then you can pull it out easily.Skids (Sid Hansen)
As Steve stated, just a tiny hole enough to start a small sheet metal screw. A pair of pliers popping the tin cover straight up without prying works fine with no casting damage.
Also, those main jets in carby in pic ARE in fact RD's. Might wanna have a closer look at the pic again. Not saying they would necessarily cause a smooth running issue, as RD main jets are really close in hole size to Genuine Mikuni. Now, if they were K&L jets, there's definitely going to be a running isssue somewhere in the rpm range, a stumble, pop,bog,etc. K&L sizing and method thereof is not even close to Mikuni sizing.
The only check I've done to verify this was take one of my 'never before chucked' drill bits, using the 'chuck' side it was a perect fit thru a 110Mikuni. Same numbered size K&L main jet rocked back and forth on the drill bit like a floppy ole' wagon wheel
. That's substantual differnence in hole size! IMO, least two step sizes.
Would be curious to see a pic of one of the pilot jets for correct no. of holes
. Would take a magnifying glass for me to see sizing and Mikuni logo on them tho
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Well, that lettering caught my attention immediately on that pictured jet. I have some of the RD main jets, and even a set that are marked 115's like his pictured. The letter stamping is also spaced wide apart the same. Last letter almost looks like an R also, but know there is no aftermarket jetting RR that I've ever heard of. Fairly positive they are RD. Definitely not G. Mikuni having no Miky logo
"You are laughing now, but trust me, you will be glad you did."
+1 on the glasses. Usually, the only clear passages are the ones pointing at your face when you spray carb cleaner into an opening."Time is the greatest teacher; unfortunately, it kills all of its students."Comment
Marco
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DONComment
Stand corrected Schming
We're good bud
Here, we all strive for accuracy, and while I'm checkin' you, someone else is checkin' me, God knows I need a checkin'
Our tireless dedication to these "Super Bikes" will ensure our grandkids kids will enjoy them further on up the road.
Glad to be a part of it.
