Carb help!
    float needles and seats
    http://www.partsnmore.com/parts/yama...100lg/?filters[fitting]=custom
      The best way to get those plugs out is to drill a small hole in them (just until you break though, deeper will damage the jets) then screw a small sheet metal screw into them. Use the screw to carefully pry them out.
      I have to disagree with this one. Only because I just did this in December and I broke out the tower prying on the stupid thing. MY suggestion is to drill them out. Use progressively larger bits. Mark the depth on the bit so you do not make contact with the screw inside there. When you get about 3/4 the dia of the plug, it should spin on the bit. Then you can pull it out easily.
      • D0wn5h1ft
        • Aug 2013
        • 515
        • Westerly, RI.
        Do this. That screw technique will cause you to break off a tower and it makes the carbs look like crap. If you have access to a drill press, go get some pilot bits and progressively larger reamers (as they have a flat head to them so it will bore through the cap and not overshoot to the top of your screw thus damaging the threads). That is what I did and it worked out great but it did take quite a bit of time because I was being extra careful.
        78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
        79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
        "May my tires not fail me, nor my engine grow cold"
          • 5073
          #34
          The same thing happened to me. The broken piece was above the idle screws so it really didn't matter unless you wanted to put some sort of seal above those. That metal is soft AND brittle. I am sure that I don't have the mechanic's touch like Steve has.
            #35
            Geez, when did I turn into 'Mr. Finesse'....
              As Steve stated, just a tiny hole enough to start a small sheet metal screw. A pair of pliers popping the tin cover straight up without prying works fine with no casting damage.
              Also, those main jets in carby in pic ARE in fact RD's. Might wanna have a closer look at the pic again. Not saying they would necessarily cause a smooth running issue, as RD main jets are really close in hole size to Genuine Mikuni. Now, if they were K&L jets, there's definitely going to be a running isssue somewhere in the rpm range, a stumble, pop,bog,etc. K&L sizing and method thereof is not even close to Mikuni sizing.
              The only check I've done to verify this was take one of my 'never before chucked' drill bits, using the 'chuck' side it was a perect fit thru a 110Mikuni. Same numbered size K&L main jet rocked back and forth on the drill bit like a floppy ole' wagon wheel. That's substantual differnence in hole size! IMO, least two step sizes.
              Would be curious to see a pic of one of the pilot jets for correct no. of holes. Would take a magnifying glass for me to see sizing and Mikuni logo on them tho.
                • 2104
                Yep, exactly the way I removed mine from my Hitachi's on my XJ 750.
                But, this:
                Doesn't look anything like these:
                  Well, that lettering caught my attention immediately on that pictured jet. I have some of the RD main jets, and even a set that are marked 115's like his pictured. The letter stamping is also spaced wide apart the same. Last letter almost looks like an R also, but know there is no aftermarket jetting RR that I've ever heard of. Fairly positive they are RD. Definitely not G. Mikuni having no Miky logo.
                  • LoHo
                    • Sep 2002
                    • 1342
                    • Fresno, CA
                    #39
                    "You are laughing now, but trust me, you will be glad you did."
                    +1 on the glasses. Usually, the only clear passages are the ones pointing at your face when you spray carb cleaner into an opening.
                      • 2104
                      Genuine Mikuni Logo:
                      . . . and quit winking at me your making me nervous.
                      • LoHo
                        • Sep 2002
                        • 1342
                        • Fresno, CA
                        #41
                        "Geez, when did I turn into 'Mr. Finesse'.... "
                        Maybe just compared to some..."Get the BIG hammer, Joe, this jet is in there TIGHT!"
                        • Prisoner6
                          • Aug 2013
                          • 1184
                          • Phoenix, AZ
                          #42
                          Yep ... in the second photo, the Mikuni logo is visible at about the 11:00 position.
                          Marco
                          1979 Honda CBX
                          2002 Kawasaki ZRX1200R
                          WE MISS YOU, DON
                            Stand corrected Schming.
                              • 2104
                              We're good bud
                              Here, we all strive for accuracy, and while I'm checkin' you, someone else is checkin' me, God knows I need a checkin'
                              Our tireless dedication to these "Super Bikes" will ensure our grandkids kids will enjoy them further on up the road.
                              Glad to be a part of it.
