I bought a pair of CB1000 air shocks off eBay supposedly in good condition. However, the package arrived saturated in oil (surprised post office delivered it). So, my question is: before I even attempt to install them, what should my first step be? I pressed on both of them, and neither one collapsed, so I guess that's a good sign. Refill with oil? How much and what kind? Where do I fill them? Are the seals bad?
CB1000 Air Shocks: Arrived in mail leaking . . .
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Tags: None -
Tom
1982 XJ1100, waiting resto to original -
Theodore RooseveltComment
AFAIK, the work you need performed on those shocks is not a DIY project. O would also suggest you contact the seller.Life is what happens while your planning everything else!
78 XS750Comment
The oil probably came out an open air line which would be normal for laying the shock on it's side. I do agree it's the sellers fault not to properly cap the lines before shipment. It probably wouldn't be too hard to figure out the oil weight/capacity (google) and just refill them, JMHO.2H7 (79) owned since '89
☮Comment
The seller contacted me and stated that if the valve was opened and the shocks were tossed around, oil would leak out. Is there any definitive way to test if the shocks are bad?1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Also, the valve did not appear to be the common Schrader air valve. It looks like an empty fitting. Any ideas as to swapping that out
The opening on the shock is probably for a plastic air line that is T'd together with the other shock and a single schrader valve to fill both shocks equally. A close up pic would be helpful some.2H7 (79) owned since '89
☮Comment
Sorry, not sure what happened to the pic
"Mindwebs" posted in my SW thread, so I guess that takes care of the bleeding question. How about the Schrader valve question?1979 XS1100F
Without pics of what you are starting with we can't really help you proceed. None of your dropbox pics ever show up.Nathan
My pics are not showing? I see the pics right now. Hmm. Heres the link to the pic:
That looks like a busted Schreader valve and the oil then leaked from there.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
I think Schming has it right. Busted Schrader valve. I'll head to Auto Zone/Advance tomorrow to see how I want to do this.1979 XS1100F
