CB1000 Air Shocks: Arrived in mail leaking . . .
    • 2075
    JAT, it might be metric, best take the original with ya . . . but you knew that.
    • James England
      • 3039
      • North of England
      I'd say almost certainly metric.
        • 7817
        My pics are not showing? I see the pics right now. Hmm. Heres the link to the pic:
        https://db.tt/4DU5e2h4
        The https: has to be changed to http: or no one will see it. This happens when people use photos from Facebook while they're signed in. The s has to be removed or the link is secure.
          • 3918
          No fitting/hydraulic/hardware store had that Schrader valve. My local small shop had a box of them. And yes, they were metric. Not sure what the other forums speak of with regard to an 1/8" fitting on the shocks. It does not fit.
            • 3918
            Okey dokey- I successfully re-filled the air shocks with 10 oz of 5wt oil each shock; no leaks. Having issues pressing the XS rubber bushings and sleeves into the air shocks. Any advice?Anyvody sell those sleeves that fit the left side bolts, and the top right side?
              • 3918
              Done! Found some plastic sleeves.
                • 2075
                Hi Ian, nice to see a plan come together, kudos.
                What type of oil did you use, fork oil ?
                I don't want to start an oil thread, Just have a set of XJ air shocks that I'd like to refresh.
                  • 3918
                  Hey Schming- I took about a week and read maybe a thousand+ pages on air shock (over oil) rebuild threads (great one on here, btw). From the factory, Showa used 5wt oil. Some guys recommended using 2.5wt, whoch I could not find. I used 5wt Belray fork oil. Others recommend 10wt for a more modern feel.
