CB1000 Air Shocks: Arrived in mail leaking . . .
    • 3918
    I bought a pair of CB1000 air shocks off eBay supposedly in good condition. However, the package arrived saturated in oil (surprised post office delivered it). So, my question is: before I even attempt to install them, what should my first step be? I pressed on both of them, and neither one collapsed, so I guess that's a good sign. Refill with oil? How much and what kind? Where do I fill them? Are the seals bad?
  • TomB
    • Aug 2006
    • 967
    • Cumbria, UK
    Tell the seller to give you your money back!!!
    Tom
      My thoughts exactly!
        AFAIK, the work you need performed on those shocks is not a DIY project. O would also suggest you contact the seller.
          • 8753
          The oil probably came out an open air line which would be normal for laying the shock on it's side. I do agree it's the sellers fault not to properly cap the lines before shipment. It probably wouldn't be too hard to figure out the oil weight/capacity (google) and just refill them, JMHO.
            • 3918
            The seller contacted me and stated that if the valve was opened and the shocks were tossed around, oil would leak out. Is there any definitive way to test if the shocks are bad?
              • 3918
              Also, the valve did not appear to be the common Schrader air valve. It looks like an empty fitting. Any ideas as to swapping that out
                • 8753
                The opening on the shock is probably for a plastic air line that is T'd together with the other shock and a single schrader valve to fill both shocks equally. A close up pic would be helpful some.
                  • 3918
                  Sorry, not sure what happened to the pic
                    • 3918
                    "Mindwebs" posted in my SW thread, so I guess that takes care of the bleeding question. How about the Schrader valve question?
                      Without pics of what you are starting with we can't really help you proceed. None of your dropbox pics ever show up.
                        • 3918
                        My pics are not showing? I see the pics right now. Hmm. Heres the link to the pic:
                          • 8753
                          If you take the end off is there a compression fitting in there?
                            • 2075
                            That looks like a busted Schreader valve and the oil then leaked from there.
                              • 3918
                              I think Schming has it right. Busted Schrader valve. I'll head to Auto Zone/Advance tomorrow to see how I want to do this.
