starter button won't work
    Look at your handle bar switch on the right side. You will need to pull the seat and tank off the bike, then you can see the connector from that switch near the coils up front on the right side of the frame.
    Look at the connector and see if it has three or four wires. Three wires will be two red/white and one blue wire. The four wire connector has those three and a black wire in it. If it has the black wire, that should be your ground in place of the bars.
      • 8930
      Originally posted by DiverDown
      I have a 1980G, and I just put new handlebars on it, and now it won't start. The old one's were chrome, these are painted. Any chance this might be the problem?
      You bet it is. Gonna have to get a good ground at that right switch housing somehow.
        • 2101
        Run a 16 gauge black wire, with a screw terminal, from a screw on the switch housings, left & right, to ground under the tank at the reg/rec.
        • DiverDown
          • Feb 2014
          • 2
          • Puyallup, Wash.
          Thanks guys. I haven't had a chance to work on the beast for a couple days, but I got it started with a screwdriver at the solenoid this afternoon. I'll work on running a grounding wire, unless I decide to change the handlebars. Again.
          '80 XS1100G - "Stripper"
          "Representation" without lubrication ...
          • Blank Slate
            • Nov 2013
            • 393
            • Ottawa, Ontario, Canada
            Originally posted by vwlord
            Well it was the fuse box. Gotta give a big shout out to TC for saving my bike.
            i was hoping a blown fuse was my problem as well, but none of the fuse blades look busted, so i am scratching my head wondering what else could it be.
            battery is charged, lights are working, i opened the starter mechanism and wires were clean and attached solidly, i cant think of any reason why the starter button all of a sudden no longer works. no pulse. dead.
            jumping it is the only way to start it and it rides fine.
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
              • 5073
              Well, if you used that starter button while jumping the bike, there isn’t anything wrong with it. A stronger battery may overcome a bad connection somewhere(?).
                • 7832
                Starter button works by grounding a wire. I would take apart the right control and check for bad/broken connections inside.
                • Blank Slate
                  • Nov 2013
                  • 393
                  -i charged the battery on the trickle charger all night. it reads 13.1 with multimeter.
                  -i did open the right controller, looked like wires were fine
                  -i sprayed electrical cleaner in it, just because... no improvement
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • Blank Slate
                    • Nov 2013
                    • 393
                    my fuse box blade configuration
                    which blade would be responsible for starter button?
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                    • Blank Slate
                      • Nov 2013
                      • 393
                      Clymer says from left to right it should be 30 main, 10headlight, 20turn, 10ignition.
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                      • Blank Slate
                        • Nov 2013
                        • 393
                        seems all is clean and firmly connected.
                        i think i need to follow that blue/white wire to find my problem
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                          • 8077
                          How did you make those crimps on the fusebox flag terminals? The flag terminals on the smaller gauge wires are too big. They should be red. If you can pull on any of those wires, and they come out, that's at least contributing to your problem.
                          Corrosion in the switchgear is no good.
                            • 7832
                            Try taking the button assembly apart. clean up all the contacts and re-assemble. Just work on the starter button for now, but you may need to do all the contacts as age IS a factor.(I can't be old yet!)
                            Also, looking at the photo the ground wire could use cleaning as well. it's the screw that holds the starter button assembly in.
                            • Blank Slate
                              • Nov 2013
                              • 393
                              i want to take the button thing apart but i dont know how it comes out. when i unscrew everything it doesn’t dislodge, do i pull it out? the ground wire (blue /white) goes into the button housing, the screw on top is soldered tight, should i rip it out???
                              Frame: 79 XS1100S
                              Engine: 81 XS1100S
                              Carbs: 78-79 BS34
                              Gf bike: 78 XS650S
                              Carbs: 70-79 BS38
                              • dpotter58
                                • Aug 2004
                                • 1866
                                • Southern Maryland
                                it comes out from the inside of the case. when you take the screw out, there's some spring pressure that hold it in places. A little wiggle and you should be good.
                                1980 LG
                                1981 LH
