starter button won't work
    There is also a connector under the tank for the starter switch that can lose contact due to corrosion or stretched pins. A good test is hook a wire to negative battery terminal and touch other end to the blue wire solder joint on the solenoid. Make sure the bike is in neutral. The engine should crank with the key on. This would verify the problem is with the switch button or the harness.
    • Blank Slate
      • Nov 2013
      • 393
      • Ottawa, Ontario, Canada
      i will try your tip phil.
      and clean the solenoid:
      Frame: 79 XS1100S
      Engine: 81 XS1100S
      Carbs: 78-79 BS34
      Gf bike: 78 XS650S
      Carbs: 70-79 BS38
      • Blank Slate
        • Nov 2013
        • 393
        i got the starter botton housing case off but the blue white wite was soldered onto it and broke off. so i gotta solder it back on.
        looking for a sharp object to seppuku myself with
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
