issues
    • 8894
    Use Photobucket or other hosting site and paste the IMG code/link here in your post.
    • Truefreak104
      • Nov 2013
      • 38
      • Florence, Or
      Ok so on my" rubber boots" I have vacume line I get that 1 and 4 go to the petcocks what do I do with 2 and 3 ....cap them or run a hose between the two
      79 xs1100 standard ....Bobber project
        2 of them (doesn't matter which 2) and 2 stay capped. Those are your syncronization ports for when you get to the point of needing to sync your carbs.
        There is also a vac port on the body of the #2 carb. This one is for the vacuum advance units hose. This is a metered vac port and should be the only place you plug the advance into.
          On both of my standards, I set them up this way:
          #1 - capped
          #2 - to carb #1
          #3 - to carb #4
          #4 - capped
          Another hint - run your fuel lines as follows:
          - from left petcock to the lower "T" fitting between carb #3 and carb #4
          - from right petcock to the lower "T" fitting between carb #1 and carb #2
          Run both of these with a bit of extra length to they will still be connected when you raise and insert a three or four inch block under the rear end of the tank, for when you are syncing the carbs.
          • Truefreak104
            • Nov 2013
            • 38
            • Florence, Or
            Right on thanks for the help..
              • 2098
              Don't forget, it's a good idea to use inline fuel filters in between the tank and carbs.
              • Truefreak104
                • Nov 2013
                • 38
                • Florence, Or
                Yea I got the fuel lines ran with filters....still having a dumb moment abour the vac lines so the 2 uncaped have lines to the petcocks correct ....also the vacuum advance had a bb shoved in the hose...wtf
                  Yes, if you have a standard then 2 vac lines go to the petcocks. Pull that bb out and hook it up to that nipple on the #2 carb body.
                  We really do need to know what year and model bike you have. A lot of things changed through the years and advice needs to be based on the year and the model you have. Look at the steering neck and the VIN is stamped into the neck there, give us the first 3 of the VIN, also compare it to the VIN on the engine case to see if they match. But to be sure of the year and model look at the steering neck.
                  • Crusty Snippets
                    • Sep 2010
                    • 428
                    • Gabriola BC
                    Rain
                    Can I assume you do not ride in a lot of rain?
                    The stock box does keep the rain out. I agree it is not the best design but I will be keeping it on Yami. Primarily because of the rain.
                    Unkle Crusty
                      Unkle Crusty
                      Yet another that believes in this myth... much like those that say not to jump start a bike from a running car engine.
                      This has been discussed numerous times, and there are a few that swear their bike stumbles in the rain because of the pods, (I still think it's because of electrical) but I ride all year long with pods. Sometimes in torrential, monsoon-like downpours, and even when going by trucks and getting hit with a tidal wave of water, the bike just keeps purring along, never missing a beat, and actually runs STRONGER in the rain.. which isn't really good when giving it gas while passing and hitting those slick painted lines.
                        Some engines even use a water injection to help improve performance. Granted that is really only on high performance supercharged and or turbo charged engines.
                        • Truefreak104
                          • Nov 2013
                          • 38
                          • Florence, Or
                          I do plan on riding in the rain...I live in oregon ...so putting in new clutch plates tomorrow ...but was goffin around and realize I only have first and neutral .....is that because its not actually ride able yet or could it be worse than me thinking iys just been sitting.....also the bike is a 79 ill get the vin numbers tomorrow I.....so far I beleve its a standard.....
                            I'm not sure of the model....I have duel front breaks but otherwise I'm not sure...picked the bike up 200.00 and within 3 days had it firing off starting fluid and a wd40 mix....bbasically I had a frame and 6 boxes of parts....title and was reg last year....I'm a noob. With xs I'm used to Harley....my petcock has a bigger line then the inside has a smaller line...also the back of the tank has a line
                            Hi True,
                            the back of the tank has a line he sez and there's the clue!
                            If you have a flush-mount gas cap it's doubly sure, you have a Standard gas tank.
                            Note that a Standard gas tank will also fit on a Special so we are not yet sure what bike you have.
                            The Standard has square gauges, headlight and signals and a 17" rear wheel
                            while the Special has round ones and a 16" rear wheel.
                            But wait! Those parts can also be swapped over.
                            What almost always nails it is the front axle location and brake caliper style.
                            If the axle is underneath the fork lower and the calipers are normal, it's a Standard.
                            If the axle is on the front of the fork lower and the calipers swivel and have tapered pads, it's a Special.
                            But hey, although it's rarely done, the entire fork complex will swap, too.
                            The only sure way to find out what model your bike was when it left the factory is to check the frame letter prefix & serial number.
                            Note that Frankenbikes have a long and glorious history on this list so whatever you got, it's good.
                            • Truefreak104
                              • Nov 2013
                              • 38
                              • Florence, Or
                              Its a standard xs I'm pretty sure
                                What do you mean by only having neutral and 1st? Do you mean with the bike sitting there stationary, you can only shift those? If that's the case, no worries. You'll have to roll the bike back and forth a bit to get it to be able to shift into another gear.
                                If you've only got neutral and 1st while riding, that's another issue we'll tackle.
