Engine Swap - XJ to F
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
Originally posted by IanDMacDonald View PostIt makes me respect those dudes from old Orange County Choppers episodes, watching them throw those engines around like they were a sack of flour.Life is what happens while your planning everything else!
Those Harley engines aren't as light as you think.....
While the big twin motors don't have the clutch and transmission attached, they have huge flywheels on the crankshaft, and they're not light....
The Sportster motor/tranny units weigh about the same as an XS motor, right around 220 lbs.Fast, Cheap, Reliable... Pick any two
To me it's not that they're that heavy, there's just no really good handholds on the things. Cooling fins on the front right and the middle drive piece on the back left. They need a place to screw a couple handles in.. lol.
Generally, after I get it into the frame, I stradle the frame like I would sit on the bike and move it around until I get it to drop into the mounts.Last edited by trbig; 11-07-2013, 04:33 PM.Try your hardest to be the kind of person your dog thinks you are.
Originally posted by BA80 View PostSo nate, you think it's easier stripping the frame to make it easier to tip the frame to remove/install the engine or just bribing a neighbor with a 6 pack to help lift the engine in or out?
In no way am I saying you should strip the frame just to put the engine in.Nathan
Thanks for the good tips! Sounds like I don't have near the dis-assembly nightmare I was dreading! I will protect the frame and keep the bike vertical with a bud and a beer!
I have been searching for the info on the washer switch with no luck, ant hints where to look?Scott
1978 R100S BMW
Pretty nice Hint Phil. Looks good and no problem knowing where it should move to. Excellent!2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Originally posted by trbig View Post
Hey Tod, and Phil,
Thank for those additions, I've put them onto the end of the Dremel Fix tech tip, should help those doing the fix and wanting to also perform the washer swap!
T.C.T. C. Gresham
New engine is here
Going to pull the motor tomorrow but wanted to practice the 2nd gear stuff on the old engine once it's out and on the bench.
In reading the tech thread I couldn't find mention of the way to hold the trans from turning once it's on the bench. From the article it looks like both the main clutch nut and the countershaft bolt (both 51 ft. lbs. of torque) will rotate the gear assembly, should I get them loose prior to disconnecting the output shaft? What about reassembly - tighten the countershaft bolt as much as I can on the bench but wait until it's in the bike to tighten and install the clutch basket?
Gotta be a better way! Thanks!Scott
1978 R100S BMW
Not quite sure what you're saying here.. but it won't matter if the transmission inadvertently turns some. It's not like it has to stay on some timing marks like the crank/cams. Think about it... While in operation, some gears turn while other lay idle.Try your hardest to be the kind of person your dog thinks you are.
I think he's talking about torqueing the counter shaft, and clutch drum nuts Tod. ( Well, technically the countershaft has bolt)
It may be against Hoyle but I just stuck a screwdriver in the teeth of the gears to keep them from turning.Last edited by BA80; 11-15-2013, 07:13 AM.Greg
