Engine Swap - XJ to F
  • XS11UFO
    • May 2012
    • 74
    • Palatka, Fla.
    #61
    Any tricks to pulling the alternator rotor without the Yamaha puller tool? 3 jaw puller work?
    Scott
    1978 R100S BMW
      The puller is just a bolt, someone here can tell you the exact size and thread. I can't remember right off the top of my head.
      I have gotten them off without the puller and without damage by just 2 or 3 good smacks with a hammer on the sides near the base. The vibration loosened them.
        #63
        The bolt is a 16mm X 1.5 thread. The "Tool" is listed with those threads, I was not sure if the end was anything special or not.
          • 8962
          It is just a bolt with no special end. It may need to be found at a bolt supplier, most hardware stores probably won't have it.
            Yes, I've used 3 jaw pullers, but if you have the proper bolt, as mentioned, along with an impact, it works much easier. Just make sure you grease the threads of the bolt if you find one, otherwise too much friction is lost going against the threads instead of pushing against the crank end.
            With the 3 jaw puller, get it as tight as you can, then a couple good hard shots to the head of the puller with a hammer will generally dislodge the rotor and send it flying across the floor. I have no idea how two pieces of beveled metal get stuck together so bad.
            • XS11UFO
              • May 2012
              • 74
              • Palatka, Fla.
              #66
              Gears are out!
              Ok, I have no idea how you guys get those gears out without splitting the cases!
              The engine that’s going into the bike has pristine gears so I plan on just swapping the washer position. I only had to split the case half’s by about ½ inch, should I pull the half’s apart to clean and redo the sealing surface? If I have to do that can I use the Permetex that’s on the shelf or do I need to the 60 mile round trip to the stealership to get Yammabond?
              Since I have both case half’s apart should I put the kick start gears in – is it worth the effort?
              I know its kinda cool but really the only time I used the kick starter was because it was there. With the removable lever you cant ride with it on and if the battery is dead the kick starter won’t help anyway. I guess the only thing it would be useful for is if I blew the starter – but it is kind of cool.
              Scott
              1978 R100S BMW
                #67
                If you have the cases open, and you have the kick start parts, you might as well put it in!
                  #68
                  It is useless as tits on a boar hog.
                  • XS11UFO
                    • May 2012
                    • 74
                    • Palatka, Fla.
                    #69
                    What about sealing the case half's, optional or necessary?
                    Scott
                    1978 R100S BMW
                      #70
                      Necessary.... There's a o-ring or two in there that have to be right.
                        #71
                        You want them sealed, I am not certain but I might make the trip for the 3-Bond or Yamabond. I think there is a different more generic brand stuff that is the same thing. Permatex will work for the bond, but I am not certain if it would be thicker than the 3-bond and make any difference to the bearings or seals where the case halfs meet.
                        • XS11UFO
                          • May 2012
                          • 74
                          • Palatka, Fla.
                          #72
                          From what I've read online threebond makes yammabond and supposedly NAPA carries it. I will try that, 1194 looks like the stuff.
                          Scott
                          1978 R100S BMW
                          • XS11UFO
                            • May 2012
                            • 74
                            • Palatka, Fla.
                            #73
                            NAPA doesn't have it, looks like Yammabond. I only see the oil pump O-ring, am I missing something?
                            Scott
                            1978 R100S BMW
                              http://www.amazon.com/Three-Bond-Liq.../dp/B0012TUVAW
