erratic idle
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    yes, I used my morgan carbtune , bike warmed up, at normal idle speed of 1000 rpm. again, could an intake leak on only one cylinder cause the high idle?
      • 5061
      It can cause a "hunting idle" yes.
      • 650mark
        • Jul 2012
        • 307
        • Mesa, Az.
        thanks for the help with this. all 4 of the rubber intake manifolds are only a few years old, all 4 of the blind plugs on the vacuum spigots are new, I just replaced all of the rubber vacuum hoses. where else should I look for a leak?
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          Yes.
          CZ
            Did you used that crappy paper gasket that is supplied with the intake boots or dis you UAE a light coat of rtv?
            Those paper gaskets I've failed in the past.
