yes, I used my morgan carbtune , bike warmed up, at normal idle speed of 1000 rpm. again, could an intake leak on only one cylinder cause the high idle?
erratic idle
thanks for the help with this. all 4 of the rubber intake manifolds are only a few years old, all 4 of the blind plugs on the vacuum spigots are new, I just replaced all of the rubber vacuum hoses. where else should I look for a leak?Comment
Did you used that crappy paper gasket that is supplied with the intake boots or dis you UAE a light coat of rtv?
Those paper gaskets I've failed in the past.Nathan
Theodore RooseveltComment
