Mounting Exhaust
    Hi Motoman,
    I am reasonably sure the peg mounts are correct for the bike.
    Will have another go at it to morrow. Not a happy biker to day
    Understand the unhappy! Having a trouble free LD ride, I easily get frustrated with my H and just park it in the corner of the mancave covered. ....which is where its been since last Sept. Giving it last rights won't ever happen, as its still in too nice cond., but the occassionl disgust and ST make it easy to forget about it for awhile.
      BIG Thanks to Tinman905 who came to the rescue to day.
      Upon his arrival he put ONE hand on the left side muffler and it jumped into place. Magic I tell you it was magic.
      Right side proved more difficult in fact he agrees it will need to be cut and re-welded. as he did not have time for that he had brought along a BRAND NEW system which turned out to be a real bear to install but eventually it all went together.
      This leaves Addie back in the " Running on Borrowed Parts " category.
      Pictures at 11
        Pictures at 11
        ......waiting for the breaking news report and pics.
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          #34
          I chopped the old exhaust so Phil didn,t try to fix it.
          BDF Special
            Pictures of Addie exhaust continuing saga.
            As promised some pictures. The top two show the missing and cracked flange of the old exhaust while the last 2 are the Borrowed shiny new exhaust.
              • 6762
              #36
              Wow thats gorgeous...I'm envious...
              • dpotter58
                • Aug 2004
                • 1865
                • Southern Maryland
                #37
                PHIL, why do I still see bungee cords on those saddlebags?
                1980 LG
                1981 LH
                  You're welcome to quit lookin'.
                    I should have cropped those pictures
                    Just have been too busy attending rallies and working and installing exhausts
                      To days news; I took Addie for a ride. Seems to be running fine.
                      Still lots to do to get ready for XSSE.
                      Too much to list.
                        BROKEN STUD Advice needed.
                        Just when you think it is safe to go back in the water...
                        After what seemed like a good run the other day to night I went to re torque the header nuts and found
                        #3 has a broken stud.
                        What is my best way of getting it out? I have about 3/16" sticking out of the head. limited tools at my disposal and not a lot of upper body strength.
                        So brute force and ignorance is not the solution.
                        shake down ride planned for saturday so I am in a time crunch too.
                          • 9980
                          This is the best thing I've found......
                          Commercial Rubbermaid Replacement Parts, Brute, Slim Jim, Step On, Untouchables, Indoor, Outdoor, configure, classics, enhance, silhouettes, metallic series, half rounds, round tops, wastemaster, defenders, crowne, atrium, collect-a-cubes, eclipse, outdoor resist, architek, aspen, towne, dimension, regent, waste contaiiners, refuse containers, resin containers, plastic containers, smoking managment, waste stream labels, wavebrake, wet mops, mopping, dust mops, handles, microfiber, brooms, dustpans, housekeeping, carts, cleaning cart, housekeeping cart, brushes, squeegees, sweepers, carpet bonnets. safety signs, safety cones, barriers, spill pads, platform trucks, workstations, utility carts, service carts, shelving, av carts, audio visual carts, bulk trucks, storage, farm carts, wheel barrows, garden carts, landscaping carts, techincal concepts, counter mount faucets, wall mount dispensers, counter dispensers, skin care, aerosol air care, aerosol dispensers, odor control, passive air, surface cleaning, surface care, washroom, accessories, urinal, foodservice, food storage, food preparation, food transport, food carriers, food pans, beverage service, table service, food monitoriing
                          A little heat helps too along with this.
                          • rdmcguy
                            • Jul 2013
                            • 515
                            • Denver, Colo.
                            #43
                            broken stud
                            Penetrating oil,
                            Heat up the aluminum around the stud ,it should expand quicker than the stud,
                            Lock a pair of vice grips on it and attempt to remove.(counterclock wise )
                            If met with strong resistance try a light touch clockwise.then back counterclock
                            Worst case scenario,Drill it and use any easy out, Carefully
                            Remember to use the correct drill bit to match easy out diameter
                            Good luck
                              • 9980
                              A pair of pliers, a screwdriver, a hammer, and a pair of vice grips..............
                              Everything a PO needs to screw up a bike....
                              OH YEAH.......and a crescent wrench.
                                |Hi Greg,
                                That looks interesting. Am I correct to say that the stud will be conventional... righty tighty lefty loosey ?
                                Some penetrating oil and a propane torch to get its attention first?
                                I only have a little piece to work with so want to increase my chances of success.
