Another #1 cylinder cold thread!
    • 3917
    Diaphragms good?
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      #77
      Couple pin holes here and there in all of them.
      But I patched Em up. No rips or anything huge.
      I'm sitting here reading EVERYTHING I can find about cold cylinders
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #78
        Okay, when I Rev it up and hold my hand over the carb, it Sucks fuel up enough to smooth out, then the colortune shows rich, optimal, then nothing but spark.
        Something is either REALLY clogged.... Or I just don't have compression.
        I have yet to do that test honestly since I don't have a gauge handy at this moment.
        But, if a ring was bad.... I'd be smoking up a storm I'd think.
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • Ken Talbot
          • 4251
          • Revelstoke, BC
          #79
          Something is either REALLY clogged.....
          Bingo - the pilot circuit in that carb is still plugged somewhere.
          Without going back and reading through this entire post, are you sure the orifice in the bottom of the float bowl is clear? WILDKAT included this photo in a tip quite a while ago:
          The tiny orifice (spooge hole) at the lower arrow supplies fuel to the tunnel at the upper arrow, which is where the brass pick-up feeds from. If there's no/not enough fuel flow hre, the pilot circuit won't work no matter how clean the rest of it is.
          There's also a couple more photos this old thread
          Ken Talbot
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #80
            You know..... You got me on that one!
            I don't think I ran the bowl in the ultrasonic. And I don't remember seeing that anywhere else.
            Oh man! This could be it!
            I took a break from working and instead I cleaned the fairing up, removed the cycle sound system in preparation for the new system.
            Then took a photo of my three babies.
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              #81
              So! If I blow air or cleaner through the little brass pipe... I only get air or cleaner out of the little hole by the gasket mating surface. I can't feel air going anywhere else.
              If I push air through the mix screw hole... It goes all over the place. But not out that brass pipe
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
                #82
                I want to say that hole in the bowl and brass tube only feed the enrichment (choke) circuit.
                When you are blowing air in the tube open the choke, see where the air goes.
                ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  #83
                  You are correct... With the choke open... It comes out of the choke.
                  Now that I know where that goes....... Darn....
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #84
                    I have the stripped down carb sitting in the strongest carb cleaner I have.
                    Bring it on!
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      #85
                      Bring it on!
                      Careful not to ruin the butterfly shaft seals!
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #86
                        ITS FIXED. MY GOD IT RUNS SO SMOOTH!
                        Loading up a video right now of me flying down the road.
                        I have some wacky wiring to sort... The vetter fairing is making my brakes turn the turn signals on..... Weird.
                        But.... I think I know what it was... And it was so dumb...
                        After I removed it from the cleaner... I was checking out all the little parts. Really... Detail looking at them.
                        I noticed... The floats had this weird wear pattern on the front of them... It ends up... The float, was rubbing on the gasket closest to the rack.
                        MYSTERY FREAKING SOLVED. GAHHHHHHH. RAWRRRR. ::flexes muscles and instantly grows a handlebar mustache::
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          #87
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            • 3917
                            I was surprised how quiet the bike was. Gotta love the whine of that Cardan driveshaft. It sounds like an electric car. Love it! Congrats on fixing it and staying vigilant on the issue. Safe riding!
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #89
                              Ever since I installed the oem headers and Jardine, I can hear all my valves, and drive train. It was really weird at first... Lol
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                                • 3917
                                Depending on your valve clearances, you should be able to hear them fairly well without a helmet on, not having OEM headers.
