Another #1 cylinder cold thread!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    #46
    Okiedokie.
    So I gotta remove the shims... Then find replacements locally... Or order the kit online... Unless someone on the forum has Em.
    Trying to get it done this month at least!
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      • 9980
      You maybe able to find them locally at the yammi shop.
      These bikes use the same size shims.....
      Kawasaki and Yamaha 2 valve shim over bucket motors, BMW K-bikes. Z1 KZ900 KZ1000 KZ1100 KL600 KLR650 KLX650 KZ1300 ZN1300 Yamaha XS400 XJ550 FJ600 FZ600 YX600 XJ650 XJ700 XJ750 XS750 XS850 XJ900 XJ1100 XS1100
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #48
        Thanks! I'll call around tomorrow see what the different shops have.
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #49
          Well, my valve tool is at home.
          But I'm out on vacation for a couple days, so I'll get right on it when I get home.
          Driving my Jeep on the highway for 3 hours SUCKED
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #50
            ALRIGHT!
            Took a little fiddling to figure out the motion pro tool. But I got it going.
            The offending in shim from my number 1 intake is out.
            It's a 265 Shim.
            The little gap happened to be right where I needed it to be, what if the little gap isn't? How do you spin them around?
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              #51
              Originally posted by sparkfly88
              ALRIGHT!
              Rotate the engine around until the cam is off the shim, then you should be able to spin/rotate the shim bucket around with a pic or something (or maybe even your finger). It'll be slick because of the oil and with no pressure from the cam pressing down on it, it'll spin, then line up the notch and viola!
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                #52
                Alright awesome. Doing that now with the exhaust on number one.
                It's a lot easier to move when the cam isn't contacting it.
                On my intake it's contacting and I forgot about it.
                Thanks!
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  #53
                  Okay.... I'm stuck at the exhaust valve.... Lol...
                  Help
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #54
                    From left to right.... The intakes are removed and written down, then put back in.
                    265/260/265/265
                    I can't figure out the exhaust because the cam spins the other direction.
                    My procedure was to push the valve down with the cam... Insert tool... Then twist cam again.
                    I can't do that with the exhaust because I don't want to spin the engine the other way...
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      • 3192
                      #55
                      You only ever spin the motor in its proper direction. The exhaust cams will open/close up when they are supposed to and that is when you need to take your measurement. Never reverse the direction of rotation in order to check valve clearance. The only thing that can lead to is problems.
                      You may have to wind the engine over a few times to get the cam position right but that is the only correct way to check. Using the MP tool you only have the option of checking one valve at a time so be sure you are doing it correctly or you may damage valves.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #56
                        Well, how can I use the motion pro tool if the cam spins the opposite direction?
                        Whenever I try to use the tool, it cocks off to the side and won't hit the bucket... So yeah...
                        Today I drove 3 hours round trip to get a Vetter mk 4 fairing!
                        Photos when I get home!
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          • 3192
                          #57
                          You place it on the other side of the head.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #58
                            Where's the facepalm emoticon when I need it...... Lol!
                            I didn't try that... Hmmmm....
                            Thanks! Lol
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              #59
                              Hey Ras,
                              I may be showing my "ignorance" here, as I've stated before I'm not a real mechanic, just a shadetree survivalist with a few years experience wrenching on my bike.
                              IF the cam chain, tensioner and such are all properly adjusted and set, then what's the concern about rotating the engine the OTHER way a 1/2 valve cam rotation to be able to use the motion pro tool, just to get the shims out and in??? I've done it on an XJ that we were working on last year, and it's easier to work/use the motion pro tool from the inner side/spark plug side of the valve bucket assembly especially when the engine is IN the frame and such!
                              I can understand a concern if the CCT was loose which would then permit chain slack and the chance of it hopping a crank sprocket tooth. But if the CCT is set correctly, then there really isn't any great amount of slack to cause this problem when rotating the engine CCW vs. it's normal CW rotation, as seen from the timing cover side.
                              But I'm willing to listen and learn from others more knowledgeable and experienced than me. Always willing to learn something new.
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #60
                                Spinning it the other way would make it so much easier... That's for sure.
                                Inquiring minds would like to know.
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
