Another #1 cylinder cold thread!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    I can't recall, did you try switching the 1 and 4 spark plug wires to see if the problem moves or stays the same?
    I tried to, but the idiots that worked on my bike got rid of my nice evenly cut suppression wires, and slapped on some copper core I think. And cut them uneven to the point of I cannot switch the two wires...
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      • 8861
      Ok, are you sure you have spark to that cylinder at all times? You can hook a timing light up to that wire and see if it is firing evenly.
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        I'm positive I have even and lots of spark.
        We timed it a couple weeks ago using cylinder one...
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          Are the plug wires long enough to swap #1 with #2 & #3 with #4? Do that and then switch the coil feed wires.
          If it's an iggy problem #2 should stay cold instead of #1.
          To see if it's fuel, feed the non-firing cylinder with gas from a Bernz torch.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Number 1 intake gasket was thin and fuel soaked. So that may have been the problem.
            Sealed with a fast bead of RIGHT STUFF.
            Now I'm working on doing the same to the other three.
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              • 8861
              Yep, it's a good idea to wipe any excess from the inside with your finger and smooth it out so there won't be a lip in there to impede the air/fuel flow.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                Yup, I'm doing that, I remembered reading about it.
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  All four "gaskets" were soft and falling apart when I removed them from the engine.
                  I guess I should have listened to the general consensus about the paper gaskets. I just used them because they came in the kit. Figured they were meant to be used.... Guess not.
                  Also, someone decided to take it upon themselves and mill a little out on my number 4 intake... I wonder why....
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    Okay. So check this out.
                    I was messing with all the vac ports while it was running.
                    Cylinder one, has a distinct push, pull going on.
                    A jet of air comes out of the port, then gets sucked back in.
                    So.... One of my valves are stuck open, or closed.... Huh?
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      Hopefully just needs a valve adjustment. Did you ever get to your friend's place for a compression check? That would have showed up there.
                      As these engines wear, the distance between the shims and the cams shrinks (The valve head seats deeper into the head, closing the valve to cam distance). Hopefully a valve didn't get burned.
                      And if a vlave was opened just a tiny bit, the air couldn't readily escape at the higher rpms.. which would have enough compression to fire then. but not lower rpm. Exactly the problem you're describing.
                      Now... Shim your valves and quit jackin' with your carbs!
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        I have not.
                        I was gonna get the compression checked if the intake sealing didn't fix the issue.
                        Guess I have to either find a way to his place... My jeeps headgasket is blown, and now my bike I'm afraid to ride more.... Lol... Decisions...
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          Well.. no real need to get a compression check now. As you can see, you have an intake valve not closing for some reason.. either shimming or bent. When you go to do the check, if there's no clearance between the valve and the cam (With the cam lobe pointed away from the bucket) then it'll most likely just need to be shimmed. If the gap measured is something really really large.... bent valve hanging open.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            Well, since it's something pretty bad ( to me )
                            Getting into a DOHC and valve shims...n such ( stuff I've never dealt with )
                            I wanna make sure I've got my bases covered, so today I spent the rest of the afternoon removing the head offa my jeep.
                            What I thought was a blown headgasket, was actually 3 bad expansion plugs...
                            At least I now have an excuse to get the valves done and have the head checked out on it.
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              It's not as bad as what you're thinking. You'll need to pull the seat/tank, then the valve cover. There's a way to do this so you won't lose your timing or anything. Hardest part will be figuring out which shims you need, since you'll be checking them all while you're there, and getting your valve cover to seal back up completely on installation. I've had the best luck with no gasket there and The Right Stuff gasket maker, but it's still @ a 50/50 chance whether I get it sealed completely with no tiny seeps or not.
                              If it is a bent valve, it's still fairly easy to pull the head.. so don't even sweat that, but here's to hoping for just needing shims.
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                Well, I needed something fixed within the week... My jeep is already apart and the parts are waiting for me to install.
                                The bike would have taken me some time because of ordering or finding shims... Then hoping it's not a bent valve...
                                I needed a vehicle. ASAP.
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
