Another #1 cylinder cold thread!
    Do you have a local bike shop? Lots of bikes used these 29mm shims, but one of them used a 29.5mm, and it won't fit in the shim bucket. Most shops will have a supply of them. Some will just swap oput with you, but I've given as much as $5 a piece for them. If you do have a local shop, either have them mic the shims or you bring a meter with you to do it. You can't tell the diference by looking at them.. even holding them on top of each other. It (The 29.5 shims) just won't fit down into the shim bucket.
    If it is a bent valve and nobody has a spare here, go to the XS triples site and inquire since their valves are the same as yours. I doubt there'll be too much of a problem getting one.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      +1 on the shim diameter!
      A while back, I went to the yamie dealer and they pulled out this old box that was full of shims and let me swap, got home and they were too big! (29.5mm) ARGHHH!
      Went back and got my two shims back.
      Called around town.... guess what, the BWM bike dealer had 29mm shims. Cost me about $6 each, but hey for 2 who cares. I got them that day!
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        Doesn't necessarily have to be from a Yammy dealer either. Kawasaki uses 29mm shims also.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #34
          OK everyone!
          I have returned.
          I made time for my precious Excelsior and removed the valve cover and measured all of my valvelash.
          I don't know which is exhaust and which is intake... So I just numbered them and measured each one.
          Then I looked at the manual. WOW my numbers are pretty far off.
          The one labeled number 2 wouldn't even let me slide the gauge through. So it's not bent, just needs a valve shimming baaaaaaaad
          Here are my results.
          79F
          "Excelsior"
          Honda gl1100 handlebar
          Vetter IV fairing with speaker system
          OE headers,Jardine slipons
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          Oe hardbags and luggage rack
          TC fuse block
          K&n filter with oe airbox
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #35
            Alright. I did the metric measurements.....
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              Originally posted by skids
              P.S. I saw the manometers for the synch. Be aware that the synch can change the mixtures at idle.
              Actually, mixtures change the sync.....
                It goes both ways moto.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  #38
                  Comments on the valve lash?
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    This is the easiest way, 1mm = .002in.
                    No need to convert to metric. Here are the charts.....
                      .05mm = .002"
                        OOPS......your right Phil, my mistake.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          #42
                          So that graph... Works by this...
                          I have to remove the Shim... See what I have, then look at the graph and it tells me what I'll actually need.... Correct?
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            Measure your clearances first, in in SAE.
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #44
                              I did. I have two photos up. One sae. The other metric.
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                                Then use the chart to figure the shim you need. Set your clearances to the widest of the specs because as these adjustments wear they close up.
                                Understand? When the valves are correctly set they are loud.
                                Which reminds me, I need to set them on my SG.
