A bit of oil will come out, but you don't need the drain the bike. Just put it up on the centerstand, and change the switch.
Neutral light not working any more
Yep, can't leave nuthin' alone... -
I would think that someone here has way too many of those things laying around and could hook you up for a lot less than $30.
No oil...time to seek out a deal on a switch==Thanks again, you guys are good.
--M.
79 F
1967 Suzuki X6 Hustler
1973 Suzuki TM 125
1979 XS1100 F
2005 Kaw. Vulcan VN800
1991 BMW K75Comment
BA80 (aka Greg) is implying that he probably has one and could sell you one for less than anyone else. He is a parts horder so he might cry a bit when he mails it but he will get over it eventually.Nathan
Theodore RooseveltComment
Sweet. If not -- found a used one $15 -- free ship--ebay. This bike will be all good soon!! Thanks again!!79 F
1973 Suzuki TM 125
1979 XS1100 F
1991 BMW K75Comment
Thanks Nate, now I got go out in that garage and find one. I've been looking for a ignition coil for Doc's bike for 3 days. I KNOW I ha 1 good one out there somewhere.
You dbl checked the switch wasn't gunked up, yes? Even if it isn't, did you try cleaning it just for grins?Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
Yup Bonz, i removed it, sanded the contact areas, and even sprayed contact cleaner generously on both ends. No luck....Time for a new (used) one.79 F
1973 Suzuki TM 125
1979 XS1100 F
1991 BMW K75Comment
Thanks for the update! Good luck with the new used one!Howard
ZRX1200
Greg, do you need a stock coil?(for Doc)
I swapped out my stockers on the SG with the VF coils, so I know I have one. (the other one is toast)
I can throw it in a 'if it fits, it ships' box. (USPS)Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Actually Doc has a set coming from andreas but if you want to give it up I'll take it. I'm pretty sure there's a dead one on the E and besides, if I ever find this other one it'll make a set.
All fixed. Was a faulty neutral switch. Got one from Andreas, green light is a go. Seems that you test with ohm-meter, shove one connecter up the switch's gigi where the screw goes in, touch one to the push-in part of the switch, and needle should jump up. All's well!79 F
1973 Suzuki TM 125
1979 XS1100 F
1991 BMW K75Comment
