Neutral light not working any more
    A bit of oil will come out, but you don't need the drain the bike. Just put it up on the centerstand, and change the switch.
      I would think that someone here has way too many of those things laying around and could hook you up for a lot less than $30.
      • MarkD
        • Jun 2013
        • 488
        • N. Michigan
        No oil...time to seek out a deal on a switch==Thanks again, you guys are good.--M.
        79 F
        1967 Suzuki X6 Hustler
        1973 Suzuki TM 125
        1979 XS1100 F
        2005 Kaw. Vulcan VN800
        1991 BMW K75
          BA80 (aka Greg) is implying that he probably has one and could sell you one for less than anyone else. He is a parts horder so he might cry a bit when he mails it but he will get over it eventually.
          • MarkD
            • Jun 2013
            • 488
            • N. Michigan
            Sweet. If not -- found a used one $15 -- free ship--ebay. This bike will be all good soon!! Thanks again!!
            79 F
            1973 Suzuki TM 125
            1979 XS1100 F
            1991 BMW K75
              Thanks Nate, now I got go out in that garage and find one. I've been looking for a ignition coil for Doc's bike for 3 days. I KNOW I ha 1 good one out there somewhere.
                • 3372
                You dbl checked the switch wasn't gunked up, yes? Even if it isn't, did you try cleaning it just for grins?
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                • MarkD
                  • Jun 2013
                  • 488
                  • N. Michigan
                  Yup Bonz, i removed it, sanded the contact areas, and even sprayed contact cleaner generously on both ends. No luck....Time for a new (used) one.
                  79 F
                  1973 Suzuki TM 125
                  1979 XS1100 F
                  1991 BMW K75
                    • 3372
                    Thanks for the update! Good luck with the new used one!
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      • Virginia Beach, VA.
                      Greg, do you need a stock coil?(for Doc)
                      I swapped out my stockers on the SG with the VF coils, so I know I have one. (the other one is toast)
                      I can throw it in a 'if it fits, it ships' box. (USPS)
                      80G (Green paint(PO idea))
                      The Green Monster
                      Got him in '04.
                      bald tire & borrowing parts
                      Scarlet
                      Got her in '11
                      Ready for the twisties!
                      81H (previously CPMaynard's)
                      Hugo
                      Cold weather ride
                        Actually Doc has a set coming from andreas but if you want to give it up I'll take it. I'm pretty sure there's a dead one on the E and besides, if I ever find this other one it'll make a set.
                        • MarkD
                          • Jun 2013
                          • 488
                          • N. Michigan
                          All fixed. Was a faulty neutral switch. Got one from Andreas, green light is a go. Seems that you test with ohm-meter, shove one connecter up the switch's gigi where the screw goes in, touch one to the push-in part of the switch, and needle should jump up. All's well!
                          79 F
                          1973 Suzuki TM 125
                          1979 XS1100 F
                          1991 BMW K75
                          • FJ111200
                            • Oct 2007
                            • 317
                            • Crewe, Cheshire, UK
                            Those lights in the dash are called "idiot lights".
                            Wonder why?
