Valve noise
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    #46
    Mystery has been solved, and it could have been very very bad.
    Whatever idiot that removed the cams last (I am withholding names to prevent further shame and embarrassment to myself ) didn't get the bolts on the intake cam sprocket tightened. They backed out and were skipping off the case.
    I was very lucky that the bolts are long enough that they weren't able to actually come out all the way or get snapped off.
    The biggest lesson I think Ive learned through all this is to work with the garage door closed so people don't distract me. Seems I lose all focus the second my mouth opens.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
      #47
      A very large bullet dodged there....
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        #48
        Noise
        That's the way to keep at it until it's found and fixed, CONGRATS !!!!!
        Some back aches, head aches, sanity and hair loss but what a good feeling !!!
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
          Good to hear you caught your error!..........Distractions doing top-end work could of been disastorious! Hope the caps didn't get 'egged' out.......but, then again, I would not even consider removing cam caps for valve shim adjustment.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            #50
            Holly chit man, I cant believe how lucky you are that it didnt eat itself up. I think there are some valuable lessons to be had, not just for you but on every ones behalf... Ever heard the saying measure twice, cut once? Not trying to be am @ss but next time someone suggests verifying torque of everything that was touched, its usually worth the extra time. Before I put any covers back on I like to take a 10-20 minute break, drink a beer or shoot a game of pool then come back and do a final torque check on everything. Glad it worked out for ya, now get out and enjoy that thing.
            Originally posted by DGXSER
            OK, two suggestions....
            1. Check the rest of the nuts and bolts you installed or didn't during your evening of working on the bike in a drunken stupor.
            2. Do not work on your bike in a drunken stupor anymore!!
            Seriously though, does sound like you might want to slow it up a little bit on the assembly processes. But yes, if your compression numbers all look good I doubt seriously you have any bent valves.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              #51
              WOW.
              So glad you found it and it wasn't a disaster.
              Good thing those bolts didn't fully back out because the cam sproket would have turned, but the cam wouldn't and that would have been real bad.
              So, the bolt head was hitting the case as the cam spun? Any real bad damage to the case? Pics?
              Stuff like this is why I read this site all the time. By reading about some hiccups that others had, it may help me not to repeat the same.
              Thanks for sharing.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • Tat2demon
                • Jun 2012
                • 718
                #52
                Originally posted by GLoweVA
                WOW.
                Thanks for sharing.
                The bolts must have just lightly been kissing the case. Just very small scratching on the case and one side on each bolt looked like it was buffed or lightly ground.
                I didnt take any pictures and with all the times I had to take that valve cover off in the last two weeks theres no way Im going to do it again lol. I read on here that a lot skip the valve cover gasket and just use RTV. Im sure it works great until you need to clean and redo it 7 times.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  #53
                  You can typically reuse the valve cover gasket if its not damaged. Ive had my cover off I believe twice and have no issues with leaks. It works nice because its stuck to the cover. Eventually it will need to be replaced, no telling how long/how many times you can reuse it.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  • Tat2demon
                    • Jun 2012
                    • 718
                    #54
                    Unfortunately the first time I took it off it came off in pieces. When I tear the bike apart this winter it will get all new seals and gaskets.
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                    • WMarshy
                      • Apr 2009
                      • 2402
                      • Mexico NY
                      #55
                      I heard a little bit of PAM cooking spray on the side you dont want it to stick and it will come right off.
                      '79 XS11 F
                      Stock except K&N
                      '79 XS11 SF
                      Stock, no title.
