Valve noise
  • Old Red
    • Jul 2012
    • 290
    • Greenville, NC
    “Everything else seemed fine. No backfiring or other strange sounds.”
    Are you saying it is running fine, on all four cylinders? If it is running on all four cylinders I doubt you have a bent valve.
    The other Earl
    80SG, 81SH, 80 standard parts bike, 81SH parts bike
    and new to me 78 standard dresser
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      Originally posted by skids
      Sorry, but it is the truth. Even if you had light contact afterwords, the stems could be bent not letting the piston/valve contact to occur because the bent valves are open. Here is the positive that you are looking for...you might be lucky. Do you feel lucky?
      I'm not necessarily looking for positive but "U R Screwed" is anything but helpful.
      Rechecked the shims, 2 were still a little on the tight side. Compression test showed fine all the way across but the motor was cold. Will check again tomorrow after I swap those two shims and am able to warm it up first.
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • Tat2demon
        • Jun 2012
        • 718
        The other Earl
        Yeah other than the one being a more noticeably loud than the others it seems to be running just fine. We got more snow yesterday so I wasnt able to take it out. Just ran it in the garage.
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
          • 5058
          In that case, you are probably in good shape. When you bend a valve stem they tend to stick in the open position, giving excessive valve to cam lobe clearance.
          • Tat2demon
            • Jun 2012
            • 718
            That would make sense.
            Its a good thing I had to work on it again. As I was, it occurred to me that I didn't torque my clutch star plate bolts when I put it back together last night.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              OK, two suggestions....
              1. Check the rest of the nuts and bolts you installed or didn't during your evening of working on the bike in a drunken stupor.
              2. Do not work on your bike in a drunken stupor anymore!!
              Seriously though, does sound like you might want to slow it up a little bit on the assembly processes. But yes, if your compression numbers all look good I doubt seriously you have any bent valves.
              • GLoweVA
                • Jun 2011
                • 1957
                • Virginia Beach, VA.
                Just a thought, but an exhaust leak may sound like 'tink' 'tink' and may seem like a valve noise.
                Try spraying some fine mist type water from a spray bottle (or smoke like from a cigar) around the headers and see if it goes 'puff' 'puff' somewhere, that'll be an exhaust leak.
                I've got a couple of leaks and I can believe that it may seem (hear) like valve noise.
                +1, if the compression numbers are all good and the shims are in(or near) spec then all should be good with the engine, then your 'extra' noise is coming from something else.
                80G (Green paint(PO idea))
                The Green Monster
                Got him in '04.
                bald tire & borrowing parts
                Scarlet
                Got her in '11
                Ready for the twisties!
                81H (previously CPMaynard's)
                Hugo
                Cold weather ride
                • Tat2demon
                  • Jun 2012
                  • 718
                  Lol no drinking that night. Just too many interruptions. It seems anytime people see me working on the bike they decide thats the best time to come talk to me.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • Tat2demon
                    • Jun 2012
                    • 718
                    I hadnt considered that. I did put in new exhaust gaskets the same day. Ill have to check that when it warms up a little out there.
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                    • Tat2demon
                      • Jun 2012
                      • 718
                      With the motor warmed up I got 170-145-165-170. The one making the noise is the 165.
                      I started a paper towel on fire for some smoke and didnt see any exhaust leak with that but Ill try again later when the gf gets home and I can use a cigarette.
                      Nate
                      K+N Air Filter
                      88 Voyager XII
                      81 XJ650 Maxim
                        • 9980
                        Two things, 1) Did you check the compression with the throttle wide open? It needs to be open to get an accurate reading. 2) Put a little oil in each cylinder and recheck.
                        If your getting 165 in the noisy one it isn't a bent valve, possibly the clearance isn't just right yet.
                        All those readings are pretty fair. The 145 is a touch low but not bent valve low.
                          • 5058
                          Oh my, that compression is way too high! Are you sure you put the head gasket back in? (just kidding)
                          • Tat2demon
                            • Jun 2012
                            • 718
                            Yep throttle was open. Will try it with oil tomorrow.
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                            • Tat2demon
                              • Jun 2012
                              • 718
                              I thought those numbers were a bit high too but its a cheap $28 gauge.
                              Nate
                              K+N Air Filter
                              88 Voyager XII
                              81 XJ650 Maxim
                                • 9980
                                Yeah, That's not the issue. It gives you an idea what's going on though. Your not testing the guage.
                                120 -130 is about normal.
