tank
Bummer man......well...like i said there are a few good guys in here with lots of parts. Andreas Weiss...is a great place to start.At this time:
1985 Goldwing Innr.
1976 cb 750 cafe racer
2007 vtx 1300
81 sx 1100 s h
81 sx 400 specialComment
Screw it. I still have the old tank off of Okie. I need to go get it sandblasted though. The paint is about 1/4" thick on that thing I've had to repair it so many times.
I've been scraping the paint off around there and it doesn't look good.
Oh well, another $125 - $150 shot in the.........foot. Not to mention the time. I GOTTA get a cheaper habit, maybe smack.Greg
I repaired a tank that was just like yours. I first de rusted the inside with various methods. Then I ground away all the paint. Then I fiberglassed the entire underside. Then I lined the inside with Red Kote. Then I sanded the fiberglass-filled sanded sanded and sanded. End product looks like new and its holding up fine but WAS ALOT OF LABOR!!!!!!!! If you can find a good tank it would be better IMHO to spend the $$ instead of the time!Comment
Buddy of mine had the same problem, only worse. Electric soldering iron and lots of flux did the trick. I wouldn't recommend it, but he even soldered it with gas still in the tank and just tilting the bad side up. It definitely can be soldered with a good iron and acid core solder.2H7 (79) owned since '89
☮Comment
That is s till salvageable. I would hit it with electrolysis to get rid of as much rust internally and externally as possible. Then sandblast it to get rid of all the paint/filler/crap on the outside.
After that, brazing (NOT soldering) will make a strong, permanent solution. As brazing flows much better than welding, it will also seek out those little pinholes and seal them too.
Then, test for leaks and do the body work and paint and you will have a like new tank. One thing I would recommend is when you are sure all is sealed up, treat the inside with phosphoric acid to slow down the rust in the future.-- Clint
1979 XS1100F - bought for $500 in 1989Comment
You want it you can have it for shipping.......Greg
Maybe a local radiator shop can fix you up? I had my CB650 tank fixed up a few years ago for about 50 bux. They braze it.
I repaired an old 3-wheeler tank for a buddy a while ago with some SilvAlloy and mapp gas. Been about 10 years and still not leaking. That tank was in BAD shape.1) Fire up Internet Explorer
2) http://www.yahoo.com
3) type "www.mapquest.com" into the Yahoo search page.
4) go about day as VP managing multi-million dollar financial contracts.Comment
Hey Courtney, I meant to respond to this earlier but got sidetracked. I have also used the REAL JB Weld, not the JB-quick stuff on a carb float post. It DID break down some time later, the JB weld was soft and squishy! But we have/use Ethanol in our fuel down here, not sure if you have it in the stuff you get across the border?? But that's why stopped recommending the use of JB WELD to fix gas tank leaks...it does NOT hold up to constant exposure to fuel....at least not to Ethanol added fuel!Gas can "seek out" way better than most things, so a good test is to use it for leaks before getting too smug about a tank.
If you are looking for a quick fix without lining the tank, and if it's hidden, you can actually use JB Weld Epoxy. Use the REAL JB Weld, not a clone. I actually JB Welded a carb post a few years back, and it held up until the owner of the bike sold it. As far as I know it's still holding up fine. YMMV.
Greg, many years/decade + ago I got some tank liner liquid from JC Whitney, but their automotive section, was designed to seal in tanks that still had small surface RUST. It worked great in the Special Tank I had on Godzilla for some 8-9 years before I swapped over to the XJ tank. I had some of it(Sealer/Liner) left over and put it IN the XJ tank as well. It's held up fine, no pealing loose, etc.! It was also for tanks holding Ethanol enhanced fuel!
Seems a shame to have to waste all of your work/paint!
T.C.T. C. Gresham
I can paint another one.
Like I said before, there was other damage I didn't see until I had it painted. It looked as though someone had dropped it upside down and it landed on the gascap. It was pushed in around the filler and somehow I didn't see that before.
I'm going to just cut my losses on this one. I still have the old tank from Okie and despite the thick paint on it I know it's solid.Greg
I think the area around the filler cap looks that way because of the manufacturing method, welding together pieces to make a tank. I just refinished mine and noticed waves and ripples where the various pieces would have met, especially around the filler cap. I spent many hours doing bodywork on an unmolested, undamaged tank. Then again, maybe someone did get pi$$ed at the tank and drop kicked it!I can paint another one.
I'm going to just cut my losses on this one. I still have the old tank from Okie and despite the thick paint on it I know it's solid."Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
Sounds like your just getting a different tank. So just for others who may be interested, I had this same issue with the tank on Banshee (my SH). Painted it, ready to put it on, loaded with gas and leakers all over the place. Mine were smaller pin holes.
I got the Caswell Coatings tank kit. A local XSive had used it on his Standard tank, and there was plenty left for my Special tank, so he sold me what he had left. It has been since 2010 and still holds up just fine. IF I had larger holes like some shown on this tank, I would JB Weld them in, and put the Caswell liner over it.
The same XSive that sold me the Caswell kit, had an issue develop with his filler neck drain rusting out inside the tank. This turns it into a tank drain instead of a filler neck drain. He used JB Weld to seal it, lasted about two years IRRC. Then he got a really wet crotch during a ride!!
He now has a replacement tank.
78 XS750Comment
Yeah, it's gonna be fixed right or replaced. I don't want to have to deal with something like that on a long trip.Greg
