    • 9980
    DAMMIT!!!!!!! This didn't show up with evaporust in the tank for a week, or while I was sanding and painting. As soon as I put gas in it POW it starts leaking. WTF?
    Any ideas on an easy fix. Solder?
    • 3192
    Ouch! That's gotta hurt! Sorry for your luck.
    Solder or brazing and then a tank liner would be my choices.
    • Courtney
      • 542
      • Nanaimo BC Canada
      Gas can "seek out" way better than most things, so a good test is to use it for leaks before getting too smug about a tank. If you are looking for a quick fix without lining the tank, and if it's hidden, you can actually use JB Weld Epoxy. Use the REAL JB Weld, not a clone. I actually JB Welded a carb post a few years back, and it held up until the owner of the bike sold it. As far as I know it's still holding up fine. YMMV.
      Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
        • 9980
        Not a big fan of liner. I'd like to stay away from that if I can.
          That sucks big time....
          Yeah, easiest permanent fix will be solder... and it might be a good idea to coat the inside of the tank in case there's any more that haven't showed up yet.
            Who is? But sometimes you have to bite the bullet....
            • Courtney
              • 542
              • Nanaimo BC Canada
              If you're going to solder or braze a tank, follow the usual safety steps of making sure there is no gas or gas vapor left in the tank of course!
                • 9980
                Headed to the tool store to price out and probably buy a mapp gas torch and some silver solder. The tank is out drying in the sun.
                  Hi Greg,
                  Brazing or Silversolder (does it really contain silver??)
                  Most solder today is lead free and pretty useless.
                  Like most things I have seen this done (not actually done it my self
                    Greg, if you can get a BIG electric soldering iron, that would be better (and safer). The gas torch is going to damage the paint for a considerable distance around the repair... DAMHIKIJK...
                      • 3192
                      A trick my grandfather used to do was to start a vehicle and put a hose on the tailpipe. Then he would insert it into the gas tank, let it run for a few minutes and go to welding. The vehicle would of course continue to run while he did the welding. He claimed this made it impossible to explode as there was not enough oxygen for that to happen. I am not sure he was correct but he fixed many a gas tank, some 1/2 full using this method. Maybe I am just lucky that he managed to stay around as long as he did too.
                        • 9980
                        I've already resigned myself to the fact that the paint is going to be FUBAR.
                        An iron won't get hot enough. Gotta heat the metal and let the solder flow into it.
                        It just made me mad AGAIN to go back and read what I just wrote about the paint.
                          • 9980
                          Just read that on another forum. A guy from the UK posted almost that same thing.
                            Greg, rinse the tank with denatured alcohol and then water before you start.
                            I still have that Venturer tank with all the holes in it that I need to finish filling. Lining it is a good idea if there might be other holes.
                            • brcree
                              • Mar 2010
                              • 388
                              • S.C.
                              gas tank
                              Just a thought......for all the trouble with this tank, I'de look on ebay and ask a couple guys in here for a better tank. A buddy of mine used the tank cream and after about a year it started flaking off something terrible.
                              At this time:
                              1985 Goldwing Innr.
                              1976 cb 750 cafe racer
                              2007 vtx 1300
                              81 sx 1100 s h
                              81 sx 400 special
