First time working on multiple carbs on the Trashboat
    #121
    It may or may not be convenient, but, try to cut the engine when it is acting up, not wanting to go above 4k. Then look at the plugs, see if they are wet, black, white....etc.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      #122
      So when it flips out, kill switch it, clutch it in, stop and check plugs.
      Got it.
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        #123
        kill it
        The kill switch is a bit delicate, for emergencies only use it if needed other wise use the ign. switch. Kill switch is only good so many times.
        Then yes turn off the engine whatever way you can and check the plugs, most likely will only tell you if one or more the floats are hanging.
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #124
          Well I rode on the highway for the first time today.
          Everything on the bike works fantastic.... Except the fuel gauge, and the throttle issue.
          I only need to move the throttle about a half inch for full throttle, I don't know if that's normal, but if I go any farther than that, the bike does its "miss miss miss choke cough blah" routine.
          It is kinda sluggish and coughy ( not back firing) below 3k rpm.
          The moment it gets above that, I take off, till I hit around 5-6 K. That's when it does its cough cough.
          I can stay at 70mph no problems, but anything above that it doesn't like at all.
          Tomorrow I'll take it for a run after work and pull the plugs.
          Today was a good wiring stress test though, I got poured on twice. Ugh.
          I think I did 60 miles today if I remember right,
          I just looked... 65.2.
          Some highway, some city.
          I used over a half tank.
          Normal?
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            • 8767
            Sounds like you are running rich, check your plug color.
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              #126
              Have the feeling I went from one extreme to the other? Lol...
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                #127
                Id disagree with your comment about the switch. Kill switch works fine for me, I use it 99.99% of the time to kill the engine then turn the key off. Its lasted over 50k miles so fay. Id say there is no concern with using it and would even go to the other extreme abd encourage you to use it. Funny things happen to switches and relays when they sit ununsed for long periods of time.
                Id say your milage isnt too far off even with the conditions described. Go buy some Seafoam and add half a can to a full tank, ride it around some and then let it sit a day or two...rinse and repeat. Do let us know what your plugs look like though.
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
                  +1......way rich......that thing has gotta be dumpin' some serious fuel.......surprised its not runnin out the exhaust............
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #129
                    So it's pouring rain out here all day...
                    Say it is running rich and my plugs are dark...
                    How would I fix this condition?
                    Carbs have been cleaned twice, float levels set, all jets replaced, intakes are new... Coils, plugs and wires are new.
                    C clips on the needles are in the middle position.
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      Sorry, haven't bothered to read back thru the threads to see what jets, the kind, and what exhaust and intake set-up your tryin' to run, but you definitely have an over-fueling issue, whatever the cause.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #131
                        Riddle me this, riddle me that....
                        Plug one
                        Two
                        Three
                        Four
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          • 8767
                          Those plugs look pretty good, not overly rich.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #133
                            I was sold on it being rich... I swore it was going to be.
                            Guess I have some other problem.
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              • 5061
                              #134
                              I agree: plugs look good FOR THE RPM AND TORQUE THAT THEY WERE COLORED-UP FOR. (caps for emphasis of course)
                                #135
                                OK, sp the plugs look fine, but it is bogging out like its got to much fuel. Well, maybe it does have to much fuel, for the spark it is getting.
                                Not sure if this is a similar situation from your description, but, I had a local XSives bike in my mancave working on a similar issue. It would start and idle ok, occasional pop or miss at idle. Then you had to rev it up above 3k to get it to take off and then once it got moving it would miss and sputter something awful with any kind of throttle input. You could just barely give it throttle and it would slowly pick up speed.
                                Eventually I got it narrowed down to bad coils.
