Just install the kickstart pedal on my 79 standard first time I kicked it it started right up. I tried this morning and it feels floppy And doesn't seem to be returning2 original positionAny thoughts
Just installed a kickstart pedal on a 79 standard
Tags: None
Maybe whoever had the clutch cover off last didn't properly set the return spring? JAT
Edit; Page 3-42 of the FSM explains the proper assembly procedure.Last edited by bikerphil; 03-24-2013, 02:42 PM.2H7 (79) owned since '89
If the inside have not been tampered with it should work.
Is it rubbing on anything, well lubed ? I seem to remember having to have the XS750 kicker I put on my 79 in just the right position for it to work freely.
Once it was working freely I loved starting it with my right palm in front of friends keeping my thumb out of the way just in case of a backfire. My 79 started before I could hardly even move the kicker and starting with my hand just was so cool.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'eComment
If you have any crank left twards the bottom end, it might spring back to position for a better kick. At least that was the way my old Honda was...Skids (Sid Hansen)
I just started to work it in seems to be getting better But still not enough to kick it over79 Kenny Roberts TributeComment
