Just installed a kickstart pedal on a 79 standard
  • Janzellotti
    • Mar 2013
    • 39
    • central florida
    Just install the kickstart pedal on my 79 standard first time I kicked it it started right up. I tried this morning and it feels floppy And doesn't seem to be returning2 original positionAny thoughts
    79 Kenny Roberts Tribute
    Maybe whoever had the clutch cover off last didn't properly set the return spring? JAT
    Edit; Page 3-42 of the FSM explains the proper assembly procedure.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      If the inside have not been tampered with it should work.
      Is it rubbing on anything, well lubed ? I seem to remember having to have the XS750 kicker I put on my 79 in just the right position for it to work freely.
      Once it was working freely I loved starting it with my right palm in front of friends keeping my thumb out of the way just in case of a backfire. My 79 started before I could hardly even move the kicker and starting with my hand just was so cool.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • Janzellotti
        • Mar 2013
        • 39
        • central florida
        It started easy the first time just moved it an inch or so
          If you have any crank left twards the bottom end, it might spring back to position for a better kick. At least that was the way my old Honda was...
          • Janzellotti
            • Mar 2013
            • 39
            • central florida
            I just started to work it in seems to be getting better But still not enough to kick it over
