Just installed a kickstart pedal on a 79 standard
  • Janzellotti
    • Mar 2013
    • 39
    • central florida
    Just install the kickstart pedal on my 79 standard first time I kicked it it started right up. I tried this morning and it feels floppy And doesn't seem to be returning2 original positionAny thoughts
    79 Kenny Roberts Tribute
    • 8861
    Maybe whoever had the clutch cover off last didn't properly set the return spring? JAT
    Edit; Page 3-42 of the FSM explains the proper assembly procedure.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      If the inside have not been tampered with it should work.
      Is it rubbing on anything, well lubed ? I seem to remember having to have the XS750 kicker I put on my 79 in just the right position for it to work freely.
      Once it was working freely I loved starting it with my right palm in front of friends keeping my thumb out of the way just in case of a backfire. My 79 started before I could hardly even move the kicker and starting with my hand just was so cool.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • Janzellotti
        • Mar 2013
        • 39
        • central florida
        It started easy the first time just moved it an inch or so
          • 5069
          If you have any crank left twards the bottom end, it might spring back to position for a better kick. At least that was the way my old Honda was...
          • Janzellotti
            • Mar 2013
            • 39
            • central florida
            I just started to work it in seems to be getting better But still not enough to kick it over
