help!!Change fuel filter.....Now won't start!
  • Janzellotti
    • Mar 2013
    • 39
    • central florida
    Ok i been out ridinng my arse off it feels as though i gained 30hp .it was two problems. one was the lines they were almost pinch so i rerouted second i was out of gas. so happyi feel like i am riding a new bike thnks all
    79 Kenny Roberts Tribute
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Don't feel bad, been there on both counts !
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
        • 5061
        Originally posted by Janzellotti
        (snip) second i was out of gas. so happyi feel like i am riding a new bike thnks all
        Tech tip: Do not run out of gas.
        Tip 2: Don't let anyone see you doing mouth to tank resussitation!
        • Nightengale
          • Jun 2011
          • 521
          • Hampton, VA.
          gald to hear it.
          xs1100 hartail bobber
          http://i1169.photobucket.com/albums/...-38-36_563.jpg
            I've run the small cone filters with no problems. However, I have the lines running from left petcock to right carb inlet and vice versa. And they often have AIR in them, but they still flow. The trick is to not have the hoses run too far below the carb bowls before they get to the inlets.
            But yeah, you got to have enough fuel in the tank to PUSH the fuel to the carbs...they are gravity fed. And because there's not that much flow thru the carb inlet, and it stops and starts, and is vented is why it doesn't work with the siphon principle.
            As stated, glad you figured it out.
