Ok, I called up Pingel and the fella said they do not sell the diaphragms but will gladly rebuild the unit for $15, seems fair enough so I sent the unit and $15 to them. For the meantime I have bypassed the unit with a piece of 1/4" metal tubing.
Pingel Update
Today at my work i took a 1/4 x 28 Allen head bolt, and used a size 45 drill bit and drilled a hole right through the center.I then cut off the head and am going to use this as my reducer.1980 XS1100 SG
Phil-whats the turnaround time for that ? I will install my piece this afternoon.1980 XS1100 SG
I am getting ready to install my pingel valve that showed but realize i have a problem, the fuel line from the petcocks is 1/4", but the inlet to the pingel valve is 5/16". I can't find a t or y connector with 1/4, 1/4, 5/16 setup.
How did you handle this?
Thanks,
Steve
Originally posted by XS1100_OEM4ME View Post79 XS1100 SF
I use 1/4" fuel line and also use slightly bigger metric fuel line-I really don't think the Pingel barbs are 5/16". My 1/4" fuel line fit over it no problem.To slip hose over tight barbs i run it under hot water in the sink and when it is hot enough i put it on the barbs.1980 XS1100 SG
Any chance of getting one of these if I send you $5? A drill press is somthing I still don't have access to.
thanks,
steve
Originally posted by oldyam80sg View PostToday at my work i took a 1/4 x 28 Allen head bolt, and used a size 45 drill bit and drilled a hole right through the center.I then cut off the head and am going to use this as my reducer.79 XS1100 SF
Sure give me an address and it will go out Tuesday.No payment needed.1980 XS1100 SG
Interesting concept, however a couple of years ago when the vacuum shutoff on my 650 Maxim became unreliable I added a simple 12v fuel shutoff valve to the system. The same valve could be added to an XS in the same way as the Pingel valve. I have used these valves for years, primarily on our ATV's due to constant float problems due to extensive trailering and have never had a problem with any of them.
As a matter of fact, the valve pictured here is off of one of the ATV's that is apart for other problems right at the second. On the bike, the petcock does only on and reserve, no prime function is needed because switch on = gas on, switch off = gas off. Prime ports (or bungs) were capped.
It takes less than an hour to install and wire to any accessory wire controlled by the ignition switch. Very simple, easy, and reliable. Also costs around $30 at most parts stores.The Old Tamer
_________________________
Originally posted by Dragon Tamer View PostInteresting concept, however a couple of years ago when the vacuum shutoff on my 650 Maxim became unreliable I added a simple 12v fuel shutoff valve to the system. The same valve could be added to an XS in the same way as the Pingel valve. I have used these valves for years, primarily on our ATV's due to constant float problems due to extensive trailering and have never had a problem with any of them.
It takes less than an hour to install and wire to any accessory wire controlled by the ignition switch. Very simple, easy, and reliable. Also costs around $30 at most parts stores.Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
So 1 person had a slight issue and the parts no good?Well guess what-that electrical part can also fail too! Nothing is 100% fool proof in case you don't know!1980 XS1100 SG
Originally posted by oldyam80sg View PostSo 1 person had a slight issue and the parts no good?Well guess what-that electrical part can also fail too! Nothing is 100% fool proof in case you don't know!Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
Octy
You can always by a brand new OEM octy. here for $79.00, I still like my pingel, and now that I know about the vacuum line restrictor insert, I should be fine for years, thanks Phil for the update
http://www.partzilla.com/parts/detai...520-01-00.html1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
I'm not trying to be disagreeable, it's just that I would be disappointed with that if I shelled out that much and had that happen. And I can assure you, if it were to happen to anyone, it would be me. I'm the guy that buys a new alternator for his car, takes it home and it's DOA right out of the box. And that's NEW not rebuilt. Once I bought a stove and it came delivered from HomeDepot and the box didn't have a mark on it. When the guys unboxed it for me the whole side of the stove was bashed in! We couldn't figure that out except it had to have happened at the factory. In any case I DON'T have a Pingel but I have my opinion, and as we all know, opinions are like a**holes, everbody has one. If you own one and are happy with it, that's great, and all the power to you. I'll stick to the stock octy since it's still working fine. Apologies to anyone I've offended, but I've beat the grim reaper a number of times in the last few years, and at 60 I don't get too worked up about some things; life is too short.Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
