Pingel Update
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Pingel Update
    Hi all. Just a update on the PINGEL I installed in place of the Octy I know I have been one of the few if not the only Octy fan, but after rebuilding mine a couple of years ago, it failed last year and CARBS FLOODED AGAIN I beleive it is due to changes in todays gas, so on Biker Phill's recomend, I bought a PINGEL vac. shutoff for about $100.00. best money spent on bike so far It fits about in place of the Octy and I plumed it with two adaptor "T's" so I could run both smaller size petcocks into one larger size PINGEL inlet and then two elbow joints anf the other "T" let me run the larger PINGEL outlet into the smalled size 2 carb fuel inlets. I capped off both "prim" nippels at the tank to make it easy and cleaner install.
    I was able to do it all with carbs on the bike, including removing the old Octy It has worked flawlessly and the hundred bucks is less then I have wasted on oil changes from carb overflow in the past Any one who has a Special and does this and the fuse box upgrade will save them tones of problems I couldn't fine my camera, so no pic's, but if any want more info, let me know if I can help
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    pingel
    those of us still octy enabled need pictures and part numbers!
    thanks
      • 8891
      Yep, I also use those on both my Std. and Special, never have to worry about flooding carbs.
      Glad that worked out for you Lon
      Edit: Link...
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Pingel
        Here is a link to the Pingel #9050-AV
        If the link doesn't work just Google "Pingel 9050-AV" and click on "shopping" and you will find it. It has a single larger inlet and outlet, so just plug a plastic "T" adapter with 2 smaller nipples and one larger nipple to alow you to connect the two "RUN" lines from your OEM petcocks to the 2 small nipples on the "T" fitting, then connect the 1 larger "T" fitting nipple to a short 1" pice of fuel line and connect the other end of the fuel line to the Pingel "inlet" nipple.
        Make the same setup to connect to the Pingel "outlet" nipple, only connect 2 plastic elbows to the two smaller nipples of the "T" fitting that you connected to the "outlet" nipples of the Pingel, this will alow you to connect the 2 carb "inlet" fuel lines to the elbows (you may be able to use a "Y" fitting in place of the "T" fitting and 2 elbows if you want, all the plastic fittings you need can be found at most auto parts stores)
        Next, you will need to connect the vac. line to one of you intake manafolds, I did this with a strait plastic addaptor as the OEM manafold fitting is smaller then the vac fitting on the Pingel, you could also use the larger extra fitting that comes with the pingel, but you would have to drill out the manafold vac. hole to install it. I removed all the lines from the OEM "prime" on the petcocks and just pluged the petcock nipples off. I tied the pingel down to the carbs using a plastic zip tie and a small pice foam rubber to cushen the vibration. hope this helps
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • mack
          • 2411
          • Ontario, Canada
          Octy
          still not a big fan of them, but welcome back.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Octy
            The OEM Octy valve is still available NOS from some dealers for about the same money, but I wouldn't take a chance with todays gas, the Pingel is designed for it, the Octy? maybe, maybe not
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              OEM NOS Octy
              http://www.boats.net/parts/detail/ya...520-00-00.html
              Here is the NOS Octy for 88 bucks, but I would still pay the extra 20 bucks for the Pingel, but if you doing a pure restoration, here it is
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Thanks
                Thanks for the "welcome back" Almost sold my bike, sold my boat instead
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  • Battle Ground, Washington
                  I have yet to have any problems with my octy, or with my OEM fuse box. Must be all this Northwest weather keeping them wet. LOL
                  1980 XS1100LG Midnight
                  1991 Honda CBR1000F Hurricane
                  A cold beer and another one!
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Fuel
                    Fuel can be different from state to state, glad you are having good luck with your bike, but the fuse box fix for 10 bucks and about 1/2 hour of your time is a no brainer even if it hasn't given you problems yet, it solved problems I didn't even know it caused
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • Aches n Pains
                      • 349
                      • Reston, Va.
                      Pictures. Pictures. I need pictures.
                      1995 KZ100P
                      Pods, jets, pipes, cam adjuster, oil cooler
                      1977 Ironhead - custom build
                      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Pictures
                        http://s955.beta.photobucket.com/use...ml?sort=3&o=47
                        See if this helps, don't have pic's
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          • 2074
                          Nice idea! I have the Pingel petcocks on mine-didn't know they had this available.
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Thanks
                            Thanks, and you only need one works great if you connect to both petcocks like I did, and I think Phil just uses one petcock and blocked the other petcock and works for him that way.
                            Sorry about the drawing (my best art work LOL) but I didn't take pic's when doing it. I have two in-line fuel filters between the Pingel "OUT" and the carbs, that is why I used a "t" and two elbows instead of one "Y" fitting, just fits better
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                              • 2074
                              I like both petcocks.They have been on there awhile and don't want to start now relying on one.
