Pingel Update
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    I like both petcocks.They have been on there awhile and don't want to start now relying on one.
    Thats why i did the drawling, It is an easy way to use both OEM petcocks, get rid of the "PRIM" nipple's, not needed at all on my bike (if I ever need to prim the carbs, just suck on the Pingel vacuume line like the OEM manual says) i spent many $$$$$ on oil changes and lots of worry about bearing damage before the PINGEL, now, never again
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      • 8794
      Yep, I like the simple setup, one petcock, one vacuum shutoff valve, one filter. To each their own.. .
      07 Triumph Tiger 1050
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Most bikes
        Hi Phil, I am not saying anything, most bikes only came with one petcock, as you know. The XS1100 frame to tank build made two just for better drain of the tank. With using one, just lean the bike and swish the fuel to the other side and Wahla, back on the road
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          • 2072
          I think i will go this route.I like the octy as i don't have an issue with it.What i don't like is all the lines you have to hook up.But as far as plugging the line in the petcock-what did you use?
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Plug's
            I cut two 1" OEM fuel line, then I had some steel "pins" left over from a DVD cabinet (the pins you push into the holes to hold the shelves up, these were solid steel, not wood, and they fit the line perfectly, can buy at hardware store) the I used four OEM wire hose clamps to hold / seal in place. Don't use vacuume caps, they will leak in time
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              • 2072
              OK i looked at my Pingel petcocks this morning. On-pointing towards front middle is reserve-off is pointing towards rear.So do i cap off any line?I wouldn't think so.Any suggestions? Should i take both lines and join them up into a "Y"? and feed them into the fuel valve?
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Test
                The easyist way IMHO is to test it. I just turned mine to "OFF" the put two lines on both nipples and the other end in a catch can, open to "ON" and mark that nipple. On my bike "on" and "res" flow from the same nipple. Cap the other nipple
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  • 2072
                  On and reserve flow from same nipple(actually called a bung) off is off so i guess i will cap off.Tank is sitting in my garage.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Does yours have a "prim" bung, that is what I capped as I don't use it ever. If not, why the two bungs per petcock? Mine are the OEM still and off is off to both bungs
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      • 2072
                      No prime bung just on off and middle is reserve.When i move lever to off no gas flows out of anything.When i move to reserve then gas flows out of off side(earlier post wrong info)and on position gas flows out of other bung.I'm thinking now i have to run a Y into Pingel valve.And no i don't have stock petcocks, I have the Pingel ones.They have the 5/16" bungs on them.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Pingel
                        Yes, if your pingel petcocks have a bung for "on" and one for "res" then a "Y" fitting will be needed if you want to keep your "res". The OEM pectcock uses a two level feed so "ON" and "RES" flow from the same bung.
                        I am calling them bung's for you, I like to play with nipples and leave the bungs alone myself
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          • 2072
                          Me too OEM4ME.Going to order the Pingel valve as it is not cheap! but worth the price in the long run.Just got some brass Y's on E Bay.
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            "Y's"
                            Hey, post a link to those Ebay brass "Y's" for some guys looking here please. Thanks
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                              • 2072
                              Actually ordered them on Amazon.com.Just type in brass 1/4" WYE and you should see them.Ordered 4 of them.
                                • 2072
                                In looking at your diagram are you not using fuel filters? I started putting on my lines today and after adding the Y brass connector i will add the fuel filter after the Y splits into 1 on each petcock side.That way i have a filter in place.
