'79 Standard Cafe'.
  • onefour
    • Jan 2013
    • 38
    • Nanaimo, BC, Canada
    Yeah I was, but I've come across a spare early style setup, so I should be alright. Thanks tho!!
    81 xs11 special. Blow thru turbo, ihi rhb5 vj11. Tunedish. Getting there... First power wheelie
    82 xj seca 750 - sold...
    79 gs750 - Stock body work, header, velocity stacks and clubmans
    86 fz750 - Sat outside for 4 years. Seized. Latest project.
    81 xs11 standard. White. Full fairing, bags, trunk, etc.
    • rambler Shawn
      • May 2012
      • 36
      • Qualicum Beach, B.C., Canada
      Thought I'd post a few (better) pics...
      79F cafe
        • 2076
        Lean & Mean
        Oughta do real well on fuel milage.
        • Nightengale
          • Jun 2011
          • 521
          • Hampton, VA.
          tank you
          is the tank bare metal or is it painted? i like the look. coming along good, stick with it and keep up the good work.
          xs1100 hartail bobber
          http://i1169.photobucket.com/albums/...-38-36_563.jpg
            Do you have a printable patter for the rotors? How many holes?
            • rambler Shawn
              • May 2012
              • 36
              Cheers. Yeah, the tank and frame are bare metal which will be clear coated satin to retain that raw finish.
              I don't have a pattern for the front rotors and I honestly don't know how many holes there are but it's still easy enough to pull one off and photo copy one to get a pattern. I'll keep that in mind when I blow this thing apart again for the final build.
              Having alot of fun with this thing. Had old cars forever and this is my first bike. They take up alot less space! and less rust to deal with Thinking about getting another soon for a wilder build.
              79F cafe
                • 2076
                Not sure if this will suit you but
                here's a link to drilled brake disc rotors courtesy of DennyZ & Ken Talbot
                I used the printable patterns on my discs and doubled the pattern by rotating it. Just have to make sure you print them in the right size.
                I think the hole count on each disc rotor was 84.
                HTH
                  HTH
                  Yeah, don't really like that pattern though.
                    • 2076
                    Hi Nathan, whatever pattern you end up choosing,when you drill your discs keep in mind the hints in the attached quote from the drilled disc rotor link:
                    "There have been reports from times past [& personal experience] that patterns in rotors --- of what ever type (holes/slots/mixtures/&c.) are best not repeated exactly. By repeating patterns perfectly one has an OUTSIDE chance of setting up unwanted harmonics under certain conditions. It's best to vary the smaller groups by a few degrees. The eye will never see 3 or 4 degrees of variance. Don't worry about differential balance. Not enuf to matter besides, it's in close [minimal rotational inertia]. Yer tire is out more than that. I've done several sets in the past and after I learned the trick never had another problem. If you ever see an XS 750 w/ a swirl "bubble" pattern it's pbly mine. [Swrilled & increasing in hole diameter] Also, one of our Canuck Bros. has a set of rotors that have 210 holes per disc --- if I rmbr the count.
                    TKAT "
                    HTH
