Ok guys, who stocks the twp oil seals for the ends of the crankshaft. I've tries nw vintage and CMS and my dealer.
Crank oil seals
Crank oil seals
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
Looks like the alternator side seal is still available from Yamarobber but the ignition side has been discontinued. Both seals are available in generic form without the raised outer ring.2H7 (79) owned since '89
source
Don't suppose you have a source and number for it would you?mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
Look around and see if you can find these listed somewhere on the net. They're a double lipped seal and I've had good luck with them.
First one is a 32X45X7 and the other one is a 32X48X8.
This isn't a bad deal for them on Ebay... Might pick up a couple each in case you mess one up on the install, or just to have as spares. They don't take up much room.
http://www.ebay.com/itm/32X45X7-TC-M...item2323ea7583
http://www.ebay.com/itm/32X48X8-TC-M...item2323ea7b1dTry your hardest to be the kind of person your dog thinks you are.
Thanx Big
You and I think a like, with my fleet growing you never know when extras will come in handy. As a side note, I made a jug removal tool off your basic design. Very smart idea, worked like a charm. Loved your engine thread too. Unfortunately I didn't see it until this one was already torn apart. Nice camera work.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
Thanks. Glad it helped someone. I've seen several destroyed cylinders posted over the years.Try your hardest to be the kind of person your dog thinks you are.
Oil seals
What about the ones you don't have to split the cases to install. Last xs north rally Andy blew his out and I had to trailer him home. If we'd had one of these handy we could have installed it on the side of the road.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
Mack, I'm pretty sure that the Yamaha OEM seals are the only ones that have the outer protruding lip where cracking the cases is needed.2H7 (79) owned since '89
☮Comment
